Versatile connectivity
This adapter allows seamless connections between HDMI output devices and VGA displays, providing flexibility for various setups. -
High resolution support
Delivering a maximum output resolution of 1920 x 1200 and supporting 1080p, this adapter ensures that visuals remain sharp and clear. -
Convenient design
The bus powered feature eliminates the need for external power sources, making it suitable for travel and on-the-go usage. -
Durable construction
Constructed with a PVC jacket and robust plastic housing, this adapter is designed for reliability and extended use. -
Wide compatibility
Compatible with a variety of HDMI and VGA devices, this adapter is well-suited for use in home theater setups, offices, and other environments.
