This HDMI to RCA converter box with audio converts a digital HDMI video source (with supporting audio) to work with analog RCA composite video televisions and displays, in both NTSC and PAL systems.
This HDMI to composite video converter provides features that ensure the highest quality output image, such as noise reduction, frame rate conversion and adaptive contrast enhancement.
With support for high-definition input resolutions up to 1080p, this RCA adapter lets you convert your HDMI signal to composite video and audio while still producing a crystal-clear picture.
This lightweight composite adapter is compact and highly portable, so you can use it virtually anywhere. Offering support for a wide range of HDTV and PC input resolutions, this versatile RCA converter is a perfect solution for using newer devices with your existing legacy displays.
The ability to convert and use your new HDMI equipped device with your older televisions or displays not only offers flexibility but also saves you the cost of upgrading hardware, making it extremely convenient for home or office applications.
To ensure easy operation and installation, this unique RCA composite video converter allows for plug-and-play installation without any additional software or drivers.
Versatile connectivity
This converter box supports a range of input and output connections including 19-pin HDMI Type-A for input and RCA for output, ensuring compatibility with various devices. -
Stable performance
Operating effectively within a range of 0°C to 40°C and suitable for 20% to 90% humidity, this product is reliable in diverse conditions. -
Compliant standards
Meets multiple regulatory standards including FCC, RoHS, WEEE, and RCM, ensuring safety and environmental compliance. -
Complete accessibility
Includes power adapter, 2 mounting brackets, and 4 screws, making setup and installation straightforward.
- StarTech.com HDMI to RCA Converter Box with Audio - Composite Video Adapter - NTSC/PAL - 1080p (HD2VID2) - video converter - black
- Video converter
- 1 x component video / audio input - RCA x 3 , 1 x HDMI output - 19 pin HDMI Type A
- 10.3 cm x 10.4 cm x 2.5 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- 1 x component video / audio input - RCA x 3 - female , 1 x HDMI output - 19 pin HDMI Type A - female
Video Input
- Analogue Video Format
- NTSC, PAL
- Voltage Required
- AC 100 - 240 V / DC 5 V
- Included Accessories
- Power adapter, 2 mounting brackets, 4 screws
- FCC, RoHS, WEEE, RCM
- 10.3 cm
- 10.4 cm
- 2.5 cm
- 225 g
- Shipping Weight
- 300 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90%
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.95 |
