StarTech.com HDMI to RCA Converter Box
Quicklinx: F5JGWS00 Mfr#: HD2VID2
48 In Stock
£62.76 ex VAT
£75.31 inc VAT
This HDMI to RCA converter box with audio converts a digital HDMI video source (with supporting audio) to work with analog RCA composite video televisions and displays, in both NTSC and PAL systems.
This HDMI to composite video converter provides features that ensure the highest quality output image, such as noise reduction, frame rate conversion and adaptive contrast enhancement.
With support for high-definition input resolutions up to 1080p, this RCA adapter lets you convert your HDMI signal to composite video and audio while still producing a crystal-clear picture.
This lightweight composite adapter is compact and highly portable, so you can use it virtually anywhere. Offering support for a wide range of HDTV and PC input resolutions, this versatile RCA converter is a perfect solution for using newer devices with your existing legacy displays.
The ability to convert and use your new HDMI equipped device with your older televisions or displays not only offers flexibility but also saves you the cost of upgrading hardware, making it extremely convenient for home or office applications.
To ensure easy operation and installation, this unique RCA composite video converter allows for plug-and-play installation without any additional software or drivers.
  • Versatile connectivity
    This converter box supports a range of input and output connections including 19-pin HDMI Type-A for input and RCA for output, ensuring compatibility with various devices.
  • Stable performance
    Operating effectively within a range of 0°C to 40°C and suitable for 20% to 90% humidity, this product is reliable in diverse conditions.
  • Compliant standards
    Meets multiple regulatory standards including FCC, RoHS, WEEE, and RCM, ensuring safety and environmental compliance.
  • Complete accessibility
    Includes power adapter, 2 mounting brackets, and 4 screws, making setup and installation straightforward.
StarTech.com HDMI to RCA Converter Box with Audio - Composite Video Adapter - NTSC/PAL - 1080p (HD2VID2) - video converter - black
Video converter
1 x component video / audio input - RCA x 3 , 1 x HDMI output - 19 pin HDMI Type A
10.3 cm x 10.4 cm x 2.5 cm
Enclosure Colour
Video converter
1 x component video / audio input - RCA x 3 - female , 1 x HDMI output - 19 pin HDMI Type A - female
Video Input
Analogue Video Format
NTSC, PAL
AC 100 - 240 V / DC 5 V
Power adapter, 2 mounting brackets, 4 screws
FCC, RoHS, WEEE, RCM
10.3 cm
10.4 cm
2.5 cm
225 g
Shipping Weight
300 g
Enclosure Colour
20 - 90%
F5JG StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £83.11
F5JG StarTech.com DC Power Adapter - 5V, 3A In Stock £11.93
Type: Signal Converter
