StarTech.com HDMI to DVI-D Video Cable Adapter - M/F
Quicklinx: 4LRJWS00 Mfr#: HDMIDVIMF
Type: Video
Length: [N/A]
Hurry, only 3 left in stock!
£8.54 ex VAT
£10.24 inc VAT
Connect DVI capable devices to HDMI -enabled devices and vice versa. The HDMIDVIMF HDMI to DVI Cable Adapter features one HDMI male connector and one DVI-D female connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
  • Versatile connection options
    This adapter enables flexible connectivity between HDMI male devices and DVI female displays, allowing compatibility with a wider range of equipment.
  • Quality video output
    Supports dual link TMDS functionality, which provides a robust video signal for sharp and clear visuals when connecting HDMI to DVI.
StarTech.com HDMI Male to DVI Female - HDMI to DVI-D Adapter - Bi-Directional - DVI to HDMI (HDMIDVIMF) - adapter
Cable
Adapter
TMDS Links
Dual link
Connector
HDMI - male
Connector (Second End)
DVI-D - female
P/N: BNDDKT30CAHV, CDP2DVIMM2MB, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVIMM6X10, MST30C2DPPD, MSTCDP122HD, SV211HDUC, SV221HUC4K, SV231DHU34K6, SV231HU34K6, SV431HU34K6, USB3DDOCKFT, USB3DOCKH2DP, USB3SMDOCK4K
Cable Type
Adapter
TMDS Links
Dual link
Connector
19 pin HDMI Type A - male
24+1 pin digital DVI - female
Limited warranty - lifetime
P/N: 45PATCH25WH, BNDDKT30CAHV, CDP2DVIMM2MB, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMIPNLFM3, MST30C2DPPD, MSTCDP122HD, SV211HDUC, SV221HUC4K, SV231DHU34K6, SV231HU34K6, SV431HU34K6, USB3DDOCKFT, USB3DOCKH2DP, USB3SMDOCK4K, USB3SMDOCKHV
4LRJ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
4LRJ StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
4LRJ StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.40
4LRJ StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
Type: Video
Length: [N/A]
