StarTech.com HDMI to DVI-D Video Cable Adapter - F/M
Quicklinx: 4LQQWS00 Mfr#: HDMIDVIFM
The HDMIDVIFM HDMI to DVI-D Video Cable Adapter features one HDMI female connector and one DVI-D male connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
  • Versatile connection
    Connects devices with 19-pin HDMI Type-A female and 24+1 pin DVI male connectors, ensuring compatibility across various equipment.
  • High-definition support
    The dual link configuration allows for clear and detailed resolution, enhancing video output quality.
  • Easy setup
    The Plug-and-Play design eliminates complex installation procedures, making it user-friendly for all experience levels.
  • Space-saving design
    The compact size makes this adapter ideal for limited spaces, ensuring a tidy setup.
StarTech.com HDMI to DVI-D Video Cable Adapter - F/M - HD to DVI - HDMI to DVI-D Converter Adapter (HDMIDVIFM) - adapter
Cable
Adapter
TMDS Links
Dual link
Connector
HDMI - female
Connector (Second End)
DVI-D - male
P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMIPNLFM3, HDMIROTMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB, RKCOND17HD, SV231DHU34K6, SV231HU34K6, SV431HU34K6
Cable Type
Adapter
TMDS Links
Dual link
Connector
19 pin HDMI Type A - female
24+1 pin digital DVI - male
Limited warranty - lifetime
4LQQ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
4LQQ StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
4LQQ StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.26
4LQQ StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
