Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com HDMI to DP Adapter, 8K 60Hz
Quicklinx: HSV4WS00 Mfr#: 148B-HDMI-DP-8K
Length: 30cm
14 In Stock
£42.21 ex VAT
£50.65 inc VAT
The StarTech.com HDMI to DisplayPort Adapter is a high-performance video converter designed to meet the needs of users requiring high quality video and audio conversion. Capable of supporting resolutions up to 8K (7680 x 4320) at 60 Hz, this adapter ensures that you can enjoy ultra-high-definition content without compromise.
With additional features such as 10-bit deep color, 2 audio channels, and the LT6711GX-U3 chipset, it delivers a rich, immersive viewing experience. The adapter is also USB-powered, adding convenience and eliminating the need for an external power source. It supports wide screen formats, making it perfect for a variety of displays and entertainment setups.
Designed for durability and reliability, it features bidirectional, active adapter technology and is compliant with DisplayPort 1.4 standards, including HDR support and Audio Return Channel (ARC). This makes it an ideal solution for connecting HDMI devices to DisplayPort monitors. Furthermore, its commitment to environmental standards, demonstrated by RoHS and WEEE compliance, ensures that your choice in this adapter is a responsible one.
  • High-resolution support
    Experience visual quality with support for resolutions up to 7680 x 4320, making it ideal for high-end computing tasks and ultra-high-definition entertainment.
  • Advanced audiovisual features
    This adapter is equipped with 10-bit deep color and 2 audio channels, ensuring a rich audiovisual experience. The LT6711GX-U3 chipset enhances performance, while USB-powered functionality adds convenience.
  • Comprehensive compatibility
    Featuring DisplayPort 1.4 compliance, this adapter supports HDR, 4:4:4 Chroma Subsampling, Audio Return Channel (ARC), and Display Stream Compression (DSC) 1.2a, ensuring compatibility with a wide range of devices and media types.
  • Robust connectivity
    With a bidirectional, active adapter design, this product ensures a reliable connection between your HDMI source and DisplayPort monitor. It supports 8K60Hz resolution for a seamless viewing experience.
  • Environmentally conscious design
    Adhering to RoHS and WEEE standards, this adapter is designed with environmental responsibility in mind, ensuring your technology choices are both high-performing and sustainable.
StarTech.com HDMI to DisplayPort Adapter, 8K 60Hz, Active Video Converter - adapter cable - 30 cm
Cable
Adapter cable
Max Output Resolution
7680 x 4320 - 60 Hz
Length
30 cm
Space grey
Connector
HDMI - male (input)
Connector (Second End)
DisplayPort - female (output)
DisplayPort 1.4
Active adapter, 8K60Hz support, Unidirectional
3-year warranty
Cable Type
Adapter cable active, 8K60Hz support, Unidirectional
DisplayPort 1.4
Length
30 cm
Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), HDR support, 4:4:4 Chroma Subsampling, Display Stream Compression (DSC) 1.2a, USB powered, 10 bit deep colour, 2 audio channels, wide screen support, LT6711GX-U3 chipset
Space grey
Adapters & Converters
7680 x 4320
Refresh Rate
60 Hz
Apple MacOS, Linux, Microsoft Windows, Ubuntu, Google Chrome OS
Connector
19 pin HDMI Type A - male (input)
20 pin DisplayPort - female (output)
Micro-USB power cable (50cm)
RoHS, WEEE, HDCP 2.2, HDCP 1.4, HDCP 2.3
32 g
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
2 cm
Shipping Weight
51 g
Limited warranty - 3 years
HSV4 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £13.82
HSV4 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HSV4 StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £20.57
HSV4 StarTech.com 13ft DisplayPort 1.4 8K 60Hz In Stock £29.12
HSV4 StarTech.com 16ft DisplayPort 1.4 8K 60Hz In Stock £35.05
Length: 30cm
