Brand
StarTech.com HDMI to DisplayPort Converter - 4K
Quicklinx: BM05WS00 Mfr#: HD2DP
Length: 25.5cm
Hurry, only 3 left in stock!
£38.40 ex VAT
£46.08 inc VAT
Connect your HDMI enabled Ultrabook or laptop to a DP monitor using this compact, USB-powered adapter. This HDMI to DisplayPort converter lets you connect an HDMI enabled video source, such as a Blu-ray player, camera, video game console or computer, to a DisplayPort monitor or projector.
The compact adapter is USB-powered and supports video resolutions up to 4K, giving you the freedom to connect your 4K HDMI equipped Ultrabook or laptop to an Ultra HD DisplayPort projector. It's the perfect solution for a variety of settings, including office boardrooms or trade shows.
This HDMI to DisplayPort converter can save you time and money. It works seamlessly with your existing setup when connecting a new source or display, eliminating cost by ensuring that you won't need to change or upgrade your main components.
The HDMI to DP adapter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. Plus, the adapter features a compact design that blends seamlessly with your workstation or entertainment center.
Using the HDMI to DisplayPort adapter, you can connect a secondary monitor to your laptop. Having the extra display offers a definite productivity boost because the added screen space means you can work more efficiently by multitasking more easily, and accomplish more in the same amount of time. It's perfect for office use where you'll often view documents, spreadsheets, and web pages across multiple screens.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This HDMI to DisplayPort (DP) converter lets you deliver high-resolution content to your DP enabled display, through the astonishing quality of Ultra HD. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications. Support for 4K makes the adapter great for video production applications such as viewing and editing post-production video or viewing camera footage from an HDMI source on your DisplayPort monitor.
  • Be more productive
    The active HDMI to DisplayPort adapter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. The adapter uses a USB port for power, avoiding the need for an extra power adapter. It also features a compact design that requires very little space at your workstation. The HDMI to DP adapter lets you add a second monitor to your laptop, providing the additional screen space you need to multitask more efficiently and accomplish more in the same amount of time. It offers a definite productivity boost, and lets you view documents, spreadsheets, and web pages across multiple screens.
  • Enjoy Ultra HD picture quality
    With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The adapter delivers Ultra HD content to your DisplayPort monitor and supports 7.1 channel surround audio. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
StarTech.com 4K 30Hz HDMI to DisplayPort Video Adapter w/ USB Power - 6 in - HDMI 1.4 (Male) to DP 1.2 (Female) Active Monitor Converter (HD2DP) - adapter cable - DisplayPort / HDMI - 25.5 cm
Cable
Adapter cable - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 30 Hz
Length
25.5 cm
Connectors
HDMI - male (input) , USB (power only) - male
Connectors (Second End)
DisplayPort - female (output)
Active adapter, 4K30Hz (3840 x 2160) support
P/N: SV211HDUC, SV221HUC4K
Cable Type
Adapter cable active, 4K30Hz (3840 x 2160) support
Interface Supported
DisplayPort / HDMI
Length
25.5 cm
USB powered, 7.1 channel Surround Sound
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Connectors
19 pin HDMI Type A - male (input) , 4 pin USB Type A (power only) - male
20 pin DisplayPort - female (output)
USB extension cable (1 m)
FCC, RoHS, HDCP 2.2
2.3 cm
1.3 cm
37 g
Shipping Width
18.5 cm
Shipping Depth
22.1 cm
Shipping Height
3.3 cm
Shipping Weight
137 g
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.79
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.72
BM05 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £8.65
BM05 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.69
BM05 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.82
BM05 StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £79.36
BM05 StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.91
BM05 StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.78
BM05 StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £21.08
BM05 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £20.29
BM05 StarTech.com DisplayPort to HDMI - 4K In Stock £14.55
BM05 StarTech.com HDMI to DisplayPort Converter - 4K In Stock £38.40
BM05 StarTech.com 2 m (6.6 ft.) HDMI to DisplayPort Cable - 4K 30Hz In Stock £61.35
BM05 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.08
BM05 StarTech.com HDMI to DisplayPort Adapter In Stock £56.75
Length: 25.5cm
Stock Status: In stock
