The AVoIP HDMI Receiver extends a 4K 60Hz HDMI signal over an existing TCP/IP network when paired with a compatible transmitter, keeping systems secure from unauthorized access and physical damage. The plug-and-play design requires no drivers or software and is compatible with all major operating systems, including Windows, macOS, and Linux, as well as hardware platforms like Intel, AMD, Snapdragon/ARM, and Apple Silicon. Easily expand your setup by adding multiple receivers to create a one-to-many configuration, making it easy to scale with your business needs for flexible and future-proof IP Video or KVM distribution. Receiver features a durable metal housing with mounting kits for wall or under-desk installation, plus rubber feet for desktop stability. RS232 and 3.5mm audio passthrough ports enable serial and audio extension.
Driver-Free Installation
The plug-and-play design requires no drivers or software and is compatible with all major operating systems, including Windows, macOS, and Linux, as well as hardware platforms like Intel, AMD, Snapdragon/ARM, and Apple Silicon. -
Scalable, Flexible, and Future-Proof
Easily expand your setup by adding multiple receivers to create a one-to-many configuration, making it easy to scale with your business needs for flexible and future-proof IP Video or KVM distribution. -
Professional-Grade Design
- StarTech.com HDMI Receiver Over IP for the IH2006 Series, 4K 60Hz - video/audio extender - HDMI
- Video/audio extender
- Form Factor
- External
- Localisation
- Australia, Europe, New Zealand, North America, United Kingdom
- Data Link Protocol
- HDMI
- Power
- AC 100-240 V
- 2-year warranty
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- HDMI
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Power, status
- 4K resolution support, steel housing, reset button
- 1 x RS-232 - terminal block , 1 x micro-USB (service) , 1 x audio line-out - mini jack female , 1 x Ethernet - RJ-45
- Included Accessories
- Mounting kit, power adapter, RS-232 terminal block, rubber feet
- RoHS, FCC, Plug and Play
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 10 Watt
- Limited warranty - 2 years
- -20 °C
- 60 °C
- 0 - 90% RH (non-condensing)
StarTech.com HDMI KVM Receiver Over IP | In Stock | £152.51 |
