StarTech.com HDMI Over IP Receiver 1080p
Quicklinx: F2GLWS00 Mfr#: ST12MHDLAN2R
£296.99 ex VAT
£356.38 inc VAT
This HDMI over IP receiver works with the HDMI Over IP Extender Kit (ST12MHDLAN2K, sold separately) and an Ethernet switch (sold separately), to receive HDMI video over your local area network (LAN) in remote locations, using Cat5 or Cat6 cabling. You can use additional receivers to distribute the HDMI signal to multiple locations or combine your remote displays to create a video wall.
In a point-to-multipoint (one source to many screens) or multipoint-to-multipoint (many sources to many screens) configuration, you can output video to over 100 additional displays. Each display requires a receiver. Remote control of serial devices is supported through RS232 extension.
With support for video resolution up to 1080p (1920 x 1080 at 60Hz), the transmitter also supports digital and analog audio to the receiver and analog audio from the receiver to the transmitter.
The kit includes an easy-to-use online app to manage your IP video distribution.
The app is available on iOS for your iPhone or iPad, Android for your smartphone or tablet, and Google Chrome browser for your desktop.
The HDMI over IP receiver includes optional shelf-mounting hardware. It uses Cat5e or Cat6 cables and works with existing network infrastructures, eliminating the expense of running proprietary cables.
StarTech.com HDMI over Ethernet Receiver for ST12MHDLAN2K with Video Wall Support - 1080p - HDMI over CAT5e or CAT6 Network Receiver (ST12MHDLAN2R) - video/audio extender - HDMI - TAA Compliant
Video/audio extender (receiver)
External
HDMI
Max Transfer Distance
100 m
AC 120/230 V / DC 12 V
11.8 cm x 13.1 cm x 3.1 cm
80 g
TAA Compliant
P/N: ST12MHDLAN2K
External
Wired
HDMI
100 m
Status Indicators
Power, status
7.1 channel audio support
1 x HDMI - 19 pin HDMI Type A female , 1 x network - RJ-45 , 1 x network - RJ-11 , 1 x microphone - mini jack , 1 x headphones / speakers - mini jack
IR receiver, 4 foot pads
1 x network cable , 1 x RJ-11 to RS-232 adapter , 1 x IR blaster cable
FCC, RoHS
TAA Compliant
External power adapter
Installed Qty
1
11.8 cm
13.1 cm
3.1 cm
80 g
0 - 80%
P/N: ST12MHDLAN2K
F2GL StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £34.45
F2GL StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
F2GL StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
F2GL StarTech.com ST12MHDLAN4K Receiver In Stock £259.38
