StarTech.com HDMI over IP Extender Kit
Quicklinx: F07MWS00 Mfr#: ST12MHDLAN2K
Accessory Type: Extension component
Hurry, only 1 left in stock!
£465.10 ex VAT
£558.12 inc VAT
This HDMI over IP extender kit distributes video to a remote location, over your local area network (LAN) and Cat5 or Cat6 Ethernet cabling. By combining this kit with additional receivers (sold separately) and an Ethernet switch (sold separately) you can distribute an HDMI source to multiple locations and create video walls using several remote displays and receivers in the same location.
You can also use multiple transmitters on the same network to distribute different video sources or connect the transmitter directly to a receiver at up to 330 ft. (100 m), in a point-to-point setup. Remote control of serial devices is supported through RS-232 extension.
With support for video resolutions up to 1080p (1920 x 1080 at 60Hz), the transmitter also supports digital and analog audio to the receiver and analog audio from the receiver to the transmitter.
The kit includes an easy-to-use online app to manage your IP video distribution.
The app is available on iOS for an iPhone or iPad, Android for a smartphone or tablet, and Google Chrome browser for a desktop.
The HDMI transmitter/receiver kit includes optional shelf-mounting hardware. It uses Cat5e or Cat6 cables and works with existing network infrastructures, eliminating the expense of running proprietary cables.
StarTech.com HDMI over IP Extender Kit with Video Wall Support - 1080p - HDMI over Cat5 / Cat6 Transmitter and Receiver Kit (ST12MHDLAN2K) - video/audio/infrared/serial extender - HDMI - TAA Compliant
Video/audio/infrared/serial extender
External
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
HDMI
Max Transfer Distance
100 m
AC 120/230 V
11.8 cm x 13.1 cm x 3.1 cm
80 g
TAA Compliant
P/N: ST12MHDLAN2R
External
Wired
HDMI
Max Resolution
1920 x 1080 @ 60 Hz
100 m
Status Indicators
Power, link OK, status
Wall mountable, daisy-chaining support
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 2 x RS-232 (input) - RJ-11 , 2 x RS-232 (output) - RJ-11 , 2 x IrDA (input) - mini jack , 2 x IrDA (output) - mini jack , 2 x audio (input) - mini jack , 2 x audio (output) - mini jack
IR receiver, IR transmitter, 8 foot pads
1 x network cable , 2 x RJ-11 to RS-232 adapter , 2 x RJ-11 phone cable
Mounting Kit
Included
Rack Mounting Kit
Included
FCC, RoHS
TAA Compliant
External power adapter
Max Supported Qty
2
AC 120/230 V
10 Watt
11.8 cm
13.1 cm
3.1 cm
80 g
Shipping Weight
200 g
0 - 80%
P/N: ST12MHDLAN2R
Stock Status: In stock
