StarTech.com HDMI over IP Extender - 1080p
Quicklinx: F2HSWS00 Mfr#: ST12MHDLNHK
10 in stock
£358.63 ex VAT
£430.35 inc VAT
Broadcast your HDMI signal to multiple locations throughout your site, using your existing network infrastructure. The HDMI over IP extender kit makes it easy for you to distribute HDMI to a remote display using your local area network. You can also use additional receivers (ST12MHDLNHR, sold separately) to distribute HDMI to multiple locations.
Unlike some video-over-IP solutions that consume your bandwidth, this HDMI over IP kit uses advanced compression to distribute high-quality HDMI video over your network, with minimal bandwidth requirements. Extending your HDMI signal using video compression saves your network resources, avoiding the hassle of a separate video network.
The HDMI over IP kit can be scaled to meet your specific needs. In a point-to-multipoint setup, you can route your HDMI signal to as many displays as you need, using additional receivers. For additional scalability, you can combine up to 99 different kits to create a multipoint-to-multipoint setup, where you can route different HDMI source signals to different displays. Mounting hardware and IR extenders are included for each transmitter and receiver to ensure tidy, professional installation and hassle-free remote operation.
The HDMI over IP kit maintains your HD video quality, supporting resolutions up to 1080p and making it easy to distribute dynamic digital signage throughout your site to attract customers.
StarTech.com HDMI Over IP Extender Kit - Advanced Compression - Transmitter & Receiver (ST12MHDLNHK) - video/audio/infrared extender - HDMI - TAA Compliant
Video/audio/infrared extender
External
Australia, New Zealand, United Kingdom, Europe, North Asia
HDMI
Max Transfer Distance
15 m
AC 120/230 V
9.7 cm x 13 cm x 2.8 cm
448 g
TAA Compliant
P/N: ST12MHDLNHR
External
Wired
HDMI
15 m
Status Indicators
Status
1080p resolution support, daisy-chaining support, 2 channels
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x IR (input) - mini jack female , 1 x IR (output) - mini jack female , 1 x audio (input) - mini jack , 1 x audio (output) - sub-mini jack
Remote control, IR receiver, IR transmitter, 8 rubber feet, screwdriver
2 x network cable , 1 x mini-USB type B to USB type A power cable , 2 x DB-9 to 2.5 mm serial adapter cable
Rack Mounting Kit
Included
FCC, RoHS
TAA Compliant
External power adapter
Installed Qty
2
AC 120/230 V
9.7 cm
13 cm
2.8 cm
448 g
0 - 80%
P/N: ST12MHDLNHR
F2HS StarTech.com HDMI Video Over IP Gigabit LAN Ethernet Extender Kit - 1080p In Stock £302.61
F2HS StarTech.com HDMI Over IP Extender Kit - 4K In Stock £496.34
F2HS StarTech.com ST12MHDLAN4K Receiver In Stock £248.16
F2HS StarTech.com HDMI over IP Extender - 1080p In Stock £358.63
Price Range Ex VAT: 300 - 500
