Broadcast your HDMI signal to multiple locations throughout your site, using your existing network infrastructure. The HDMI over IP extender kit makes it easy for you to distribute HDMI to a remote display using your local area network. You can also use additional receivers (ST12MHDLNHR, sold separately) to distribute HDMI to multiple locations.
Unlike some video-over-IP solutions that consume your bandwidth, this HDMI over IP kit uses advanced compression to distribute high-quality HDMI video over your network, with minimal bandwidth requirements. Extending your HDMI signal using video compression saves your network resources, avoiding the hassle of a separate video network.
The HDMI over IP kit can be scaled to meet your specific needs. In a point-to-multipoint setup, you can route your HDMI signal to as many displays as you need, using additional receivers. For additional scalability, you can combine up to 99 different kits to create a multipoint-to-multipoint setup, where you can route different HDMI source signals to different displays. Mounting hardware and IR extenders are included for each transmitter and receiver to ensure tidy, professional installation and hassle-free remote operation.
The HDMI over IP kit maintains your HD video quality, supporting resolutions up to 1080p and making it easy to distribute dynamic digital signage throughout your site to attract customers.
Reliably Extend Compressed HDMI Video with Bandwidth Efficiency
This extender uses advanced compression to distribute high-quality HDMI video over your network, with minimal bandwidth requirements. With advanced compression technology, broadcasting your video signal requires only 6 - 12 Mbps of local area network bandwidth, when in operation for each kit. -
Flexible & Scalable Deployment Options
The HDMI over LAN extender offers many configurations to accommodate your set up. This HDMI video extender provides four ways to control your video network configurations. • Rotary DIP switches located on the Tx and Rx • Your computer connected to the transmitter or receiver via a serial cable • Over IP using any device equipped with a browser on the same local area network (i.e. tablet, laptop, smartphone) • Infrared (IR) remote control using the included receiver -
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
- StarTech.com HDMI Over IP Extender Kit - Advanced Compression - Transmitter & Receiver (ST12MHDLNHK) - video/audio/infrared extender - HDMI - TAA Compliant
- Video/audio/infrared extender
- Form Factor
- External
- Localisation
- North Asia, Europe, United Kingdom, Australia, New Zealand
- Data Link Protocol
- HDMI
- Max Transfer Distance
- 15 m
- Power
- AC 120/230 V
- 9.7 cm x 13 cm x 2.8 cm
- 448 g
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: ST12MHDLNHR
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- HDMI
- 15 m
- Status Indicators
- Status
- Daisy-chaining support, 1080p resolution support, 2 channels
- 1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x IR (input) - mini jack female , 1 x IR (output) - mini jack female , 1 x audio (input) - mini jack , 1 x audio (output) - sub-mini jack
- Included Accessories
- Screwdriver, remote control, IR receiver, IR transmitter, 8 rubber feet
- Cables Included
- 2 x network cable , 1 x mini-USB type B to USB type A power cable , 2 x DB-9 to 2.5 mm serial adapter cable
- Rack Mounting Kit
- Included
- FCC, RoHS
- TAA Compliant
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 120/230 V
- 9.7 cm
- 13 cm
- 2.8 cm
- 448 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
- P/N: ST12MHDLNHR
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com HDMI Over IP Extender Kit - 4K | In Stock | £464.90 |
StarTech.com Ceiling TV Mount - Long Pole | In Stock | £136.15 |
StarTech.com ST12MHDLAN4K Receiver | In Stock | £259.38 |
StarTech.com Ceiling TV Mount, Back-to-Back | In Stock | £209.05 |
