StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m -IR Support
Quicklinx: FLW9WS00 Mfr#: ST121HD20L
Hurry, only 1 left in stock!
£331.68 ex VAT
£398.01 inc VAT
4K HDMI Balun Visually Lossless Compression IR Support. This HDMI over CAT6 extender lets you transmit your HDMI signal over a CAT6 cable up to 330 ft. (100 m) away. The extender supports Ultra HD 4K with support for 3D and the accompanying digital audio.
Long-Distance Transmission
Extend your HDMI signal to up to 330 ft. (100 m) with this HDMI over Ethernet extender. Use your existing CAT6 cable infrastructure with a direct connection to the converter for an easy run through walls and ceilings, saving you on installation costs.
The extender also works to extend an infrared (IR) signal, enabling you to control your video source from the remote location.
Astonishing 4K Picture Quality
This HDMI Ethernet extender supports a 4K 60Hz (3840 x 2160) UHD resolution, providing four times the picture quality of high-definition (1080p), ensuring a crystal-clear picture that's ideal for displaying your 4K video content in office buildings, airports, retail settings and more.
Plus, because the extender supports 1080p and lower resolutions at up to 460 feet away, you can comfortably use this extender to make any video source look great.
Compatible with HDCP 2.2 Devices
Connect your HDMI devices and displays with confidence, knowing this extender is HDCP 2.2 compliant. This lets you harness the capabilities of HDMI-enabled devices such as Blu-ray players or online streaming devices in higher resolutions. It is also backward compatible with previous generations of HDMI and HDCP.
ST121HD20L is backed by 2-year StarTech.com warranty with free lifetime technical support.
  • Long-Distance Transmission
    Extend your HDMI signal to up to 330 ft. (100 m) with this HDMI over Ethernet extender. Use your existing CAT6 cable infrastructure with a direct connection to the converter for an easy run through walls and ceilings, saving you on installation costs. The extender also works to extend an infrared (IR) signal, enabling you to control your video source from the remote location.
  • Astonishing 4K Picture Quality
    This HDMI Ethernet extender supports a 4K 60Hz (3840 x 2160) UHD resolution, providing four times the picture quality of high-definition (1080p), ensuring a crystal-clear picture that's ideal for displaying your 4K video content in office buildings, airports, retail settings and more. Plus, because the extender supports 1080p and lower resolutions at up to 460 feet away, you can comfortably use this extender to make any video source look great.
  • Compatible with HDCP 2.2 Devices
    Connect your HDMI devices and displays with confidence, knowing this extender is HDCP 2.2 compliant. This lets you harness the capabilities of HDMI-enabled devices such as Blu-ray players or online streaming devices in higher resolutions. It is also backward compatible with previous generations of HDMI and HDCP. ST121HD20L is backed by 2-year StarTech.com warranty with free lifetime technical support.
StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m - IR Support - HDMI Balun - 4K Video over CAT6 (ST121HD20L) - video/audio/infrared extender - HDMI
Video/audio/infrared extender
External
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
HDMI
Transmission Medium
CAT 6
Max Transfer Distance
140 m
AC 120/230 V
11.1 cm x 7.6 cm x 2.6 cm
271 g
External
Wired
HDMI
Max Resolution
3840 x 2160 @ 60 Hz
140 m
Status Indicators
Power, link OK
7.1 channel audio support, Dolby TrueHD support, DTS-HD support, Dolby Digital support
HDCP 1.4, HDCP 2.2
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female
4 mounting brackets, IR kit
Network cable , 2 x DB-9 to 3.5 mm serial adapter cable
Rack Mounting Kit
Included
FCC, RoHS, REACH
External power adapter
Installed Qty
2
AC 120/230 V
11.1 cm
7.6 cm
2.6 cm
271 g
Shipping Width
24.8 cm
Shipping Depth
19.5 cm
Shipping Height
9.5 cm
Shipping Weight
1.424 kg
-5 °C
0 - 95% (non-condensing)
FLW9 StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £25.96
FLW9 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
FLW9 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
FLW9 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
FLW9 StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £24.69
FLW9 StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £36.43
