StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m)
Quicklinx: 97QGWS00 Mfr#: ST121HDBTPW
Hurry, only 1 left in stock!
£327.04 ex VAT
£392.44 inc VAT
Extend HDMI up to 330ft (100m) over CAT5/CAT6 cable with Power over Cable to Receiver. This HDBaseT extender Kit, extends HDMI up to 330 feet (100 Meters) over a single CAT5e or CAT6 cable. The extender supports Ultra HD and Full HD resolutions (4K / 1080p) with support for 3D and the accompanying 7.1 digital audio. For added versatility, both the transmitter and receiver can be powered by the same single power source using Power Over Cable (POC). The versatility of this video extender makes it an ideal solution for digital signage applications in large buildings such as commercial shopping centers, stadiums, schools, and hospitals.
HDBaseT is a standardized, zero latency, video distribution technology that's revolutionizing HDMI distribution. HDBaseT uses an advanced method of modulation that enables you to distribute uncompressed HDMI audio and video, along with additional signals such as 100BaseT Ethernet, IR, RS-232 serial and power over cable.
For greater versatility than a traditional HDMI extender or HDMI cabling alone, this HDBaseT extender offers HDMI + Power Over Cable in a single kit. The added benefit of power over cable means you'll only need one power source at either side of your extension, great for extending to areas where power outlets may be limited.
With the A/V industry quickly adopting 4K as the new high-resolution video standard, long range video distribution can be a challenge with standard HDMI cables beginning signal degradation at 30 feet.
With HDBaseT you'll be amazed at how Ultra HD picture quality, four times the resolution of high-definition 1080p can be maintained even at 330 feet away from your video source. Plus, because the extender supports High-Definition 1080p and lower resolutions at 330, you can comfortably use this extender to make any video source look great, while future proofing your setup for 4K implementation.
This extender has been specially crafted for a smooth, tidy setup. HDBaseT technology allows for single cable installation, for seamless integration using existing CAT5e or CAT6 infrastructure, avoiding the hassle of running multiple cables, while reducing potential failure points. Plus, the added benefit of power over cable means you'll only need one power source to power both your extender and receiver, great for extending to areas where power outlets may be limited. Mounting hardware is also included for both the extender and receiver for discrete, professional mounting.
StarTech.com 330 ft. (100 m) HDMI Over CAT5e / CAT6 Extender - HDMI over CAT5e - HDBaseT Extender - 4K30 - HDMI Video Extender (ST121HDBTPW) - video/audio extender
Video/audio extender
External
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 120/230 V
6.7 cm x 8 cm x 2.5 cm
310 g
P/N: ST121HDBTRP, SVA12M2NEUA, SVA12M5NA
External
Wired
Max Resolution
3840 x 2160
100 m
7.1 channel audio support
1 x HDMI
FCC, RoHS
External power adapter
AC 120/230 V
6.7 cm
8 cm
2.5 cm
310 g
0 - 80% (non-condensing)
97QG StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £26.40
97QG StarTech.com 75ft Orange Cat6 Patch Cable In Stock £26.31
97QG StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.63
97QG StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £193.15
97QG StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £95.58
97QG StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £327.04
97QG StarTech.com HDMI over CAT6 with USB - 50m In Stock £172.74
97QG StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
97QG StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
97QG StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m -IR Support In Stock £341.06
