Extend HDMI up to 165ft (50m) over Cat5e/6 cabling with Power over Cable to Receiver. The ST121SHD50 HDMI over Cat5e/Cat6 Video Extender kit lets you extend HDMI video and audio by up to 165 feet (50 Meters) over dual Cat5e cables, or 130 feet (40 Meters) over dual Cat6 cables. For added versatility the kit features Power Over Cable and only requires a single power adapter that can be connected to either the Transmitter or Receiver.
With support for High-Definition resolutions of up to 1920x1080 / 1080p and the accompanying digital audio, this cost-effective HD extender can easily be installed using new or existing Ethernet infrastructure wiring. For a convenient plug-and-play installation, the HDMI extender features built-in EDID monitor emulation, which ensures native resolution and maximum compatibility with your display or projector.
For added flexibility and convenience, HDMI cables up to 32ft (10m) can be connected to both the local and remote units, which lets you extend your HDMI signal to even further distances.
The HDMI extender kit offers a point-to-point digital signage solution right out of the box, including both local transmitter and remote receiver units, along with optional hardware that lets you mount the units as needed. Plus, with Power Over Cable, you can easily extend an HDMI signal in areas where access to power outlets is limited.
- StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 165 ft (50m) HDMI Video/Audio Over Dual Ethernet Cable Extender (ST121SHD50) - video/audio extender
- Video/audio extender
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Transmission Medium
- CAT 5e/6
- Max Transfer Distance
- 50 m
- Power
- AC 120/230 V
- 5.1 cm x 8 cm x 2.1 cm
- 157 g
- 2-year warranty
- Designed For
- P/N: ST128HDMI2, SVA12M2NEUA, SVA12M5NA, VIDWALLMNT
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1080 / 1080p
- 50 m
- Status Indicators
- Power
- 1 x video - HDMI - 19 pin HDMI Type A
- Mounting Kit
- Included
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 5.1 cm
- 8 cm
- 2.1 cm
- 157 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.49 |
StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £29.25 |
StarTech.com 75ft Orange Cat6 Patch Cable | In Stock | £29.25 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.41 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.52 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £215.74 |
StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £96.70 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.88 |
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £359.75 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £54.08 |
StarTech.com HDMI over CAT6 with USB - 50m | In Stock | £183.24 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com 4K 60Hz HDBaseT extender - 70m (100m @ 1080) | In Stock | £436.10 |
StarTech.com HDMI over CAT6 Extender | In Stock | £105.96 |
StarTech.com HDMI over CAT6 Extender - 4K 60Hz - 330ft / 100m -IR Support | In Stock | £372.19 |
