StarTech.com HDMI KVM Extender Over Fiber
Quicklinx: BLK3WS00 Mfr#: SV565FXHD
Operate the keyboard and mouse while viewing the HDMI display of a PC or KVM switch, from up to 1km (3280ft) away over fiber optic cabling. This HDMI KVM extender gives you the freedom to control your HDMI enabled server or computer from up to 1 kilometer (3280 feet) away, using an SC fiber infrastructure. You can also control multiple computers or servers, using this extender with any HDMI KVM switch.
The extender offers complete remote operation by extending the keyboard and mouse (USB or PS2) for your computer, as well as the IR signal for your Blu-ray or set-top box remote control.
Extend your KVM console to greater distances by using fiber optics instead of copper wiring. Fiber optics utilizes the speed of light, greatly increasing the signal distance and reliability compared to copper extenders.
Plus, because the extender transmits data using light rather than electricity, your console signal won't cause or be affected by electromagnetic interference (EMI), making it ideal for hospitals or other sensitive environments.
This console extender not only lets you access your computer from up to a kilometer away, but it delivers PC resolutions up to 1920x1200, or high-definition television resolutions of 1080p. This performance ensures your console extender can be used for resource-intensive applications such as AutoCAD design, or editing videos or photographs.
With support for both multi-mode and single-mode fiber, you can use this extender with virtually any fiber optic run by simply terminating or coupling your fiber using an SC-SC connector. Great for utilizing existing infrastructure, and extending your console across or between buildings.
StarTech.com HDMI over Fiber KVM Console Extender - USB or PS2 Keyboard and Mouse - Single mode or Multimode - KVM support - 1KM (3280ft) (SV565FXHD) - KVM / audio / infrared extender - Fibre Channel, HDMI
External
Fibre Channel, HDMI
Transmission Medium
Fibre optic
Max Transfer Distance
2 km
13 cm x 2.8 cm x 13.2 cm
560 g
External
Wired
Fibre Channel, HDMI
Max Resolution
1080p
2 km
Status Indicators
Status
1 x HDMI (output) - 19 pin HDMI Type A female , 2 x - SC multi-mode female , 1 x IrDA (input) female , 2 x USB 2.0 (input) female , 1 x HDMI (input) - 19 pin HDMI Type A female , 1 x USB 2.0 (output) - Type B , 1 x PS/2 mouse (output) - 6 pin DIN , 1 x IrDA (output) female
IR sensor
1 x PS/2 Y-cable , 1 x fibre optic cable - 2 m
FCC, RoHS
13 cm
2.8 cm
13.2 cm
560 g
0 - 80%
BLK3 StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub In Stock £157.19
BLK3 StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch In Stock £74.78
