StarTech.com HDMI Extender over CAT6 4K PoC
Quicklinx: GR5ZWS00 Mfr#: EXTEND-HDMI-4K40C6P1
15 In Stock
£94.48 ex VAT
£113.37 inc VAT
This HDMI Extender over CAT6 lets you transmit a 4K 30Hz HDMI audio video signal up to 130ft (40m), or 230ft (70m) for 1080p resolutions. This converter kit includes both the transmitter and receiver for a complete end-to-end solution.
  • 4K Picture Quality
    This HDMI extender supports 7.1ch audio and resolutions of up to 4K at 30Hz (3840 x 2160) over a single CAT6/5e cable. The UHD HDMI Extender supports HDMI 1.4 and 4:4:4 chroma subsampling, which ensures a crystal-clear picture.
  • Simplify your setup
    With support for Power over Cable (PoC), only one power, connected to the transmitter, is required to power both units of the transmitter and receiver kit. IR extension, using the included IR Blaster and Receiver, makes controlling a source device from a remote location easy.
  • Easy Installation
    The 4K HDMI Extender over Ethernet cable has an HDMI output on the transmitter unit allowing the solution to be cascaded to other video extenders or for use to a local display. Plug-and-play installation with no additional software or drivers required. The metal housing and built-on mounting brackets allow for professional installation options, ideal for digital signage, boardrooms, and tradeshow applications. EXTEND-HDMI-4K40C6P1 is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com HDMI Extender over CAT6/CAT5, 4K 30Hz/130ft (40m) or 1080p 60Hz/230ft (70m) Video Extender, 4K HDMI over Ethernet Extender, PoC HDMI Transmitter and Receiver Kit, IR Extension - Local Video Output - video/audio extender - HDMI
Video/audio extender
External
Data Transfer Rate
10.2 Gbps
HDMI
Transmission Medium
CAT 5/6
Max Transfer Distance
70 m
Power Over Ethernet (PoE)
PoC
AC 100-240 V
6.9 cm x 5.7 cm x 1.7 cm
130 g
External
Wired
HDMI
Data Transfer Rate
10.2 Gbps
Max Resolution
4096 x 2160 @ 30 Hz
70 m
Status Indicators
Power, link
7.1 channel audio support
2 x HDMI (local unit) female , 1 x network (local unit) - RJ-45 female , 1 x audio (local unit) - phone 3.5 mm female , 1 x HDMI (remote unit) female , 1 x network (remote unit) - RJ-45 female , 1 x audio (remote unit) - phone 3.5 mm female
IR receiver, IR blaster extension cable
RoHS, WEEE, RCM
PoC
External power adapter
Installed Qty
2
AC 100-240 V
6.9 cm
5.7 cm
1.7 cm
130 g
Shipping Width
20 cm
Shipping Depth
11.3 cm
Shipping Height
7.5 cm
Shipping Weight
500 g
20 - 90% (non-condensing)
GR5Z StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GR5Z StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.37
GR5Z StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
GR5Z StarTech.com 4K HDMI Extender, 4K 60Hz HDR In Stock £161.55
GR5Z StarTech.com HDMI Extender, 4K 60Hz, 200ft In Stock £108.91
