StarTech.com HDMI Extender, 4K 60Hz, 200ft
Quicklinx: J4KVWS00 Mfr#: 4K50IC-EXTEND-HDMI
More than 50 In Stock
£109.90 ex VAT
£131.88 inc VAT
The HDMI Extender is designed to transmit visually lossless and low latency 4K 60Hz video and 7.1 channel audio up to 200 feet (60 meters) over a single network cable. This HDMI over CAT5e extender is HDMI 2.0 compliant and supports up to 4K 60Hz resolutions, HDR, HDCP 2.2, DTS, and Dolby Digital audio. This makes it suitable for high-quality video and audio transmission over long distances. The extender features Power-over-Cable (PoC) technology, allowing the included power adapter to connect only to the transmitter while providing power to both the transmitter and receiver through the CAT5e/6 cable. This feature reduces the need for additional power sources at the receiver end. A point-to-point connection uses a single CAT6/5e cable and requires no drivers, software, or IP configuration, significantly reducing setup time. The HDMI extender can be mounted on a wall, ceiling, or the underside of a table using the included brackets.
  • 4K 60Hz Resolution
  • Power-Over-Cable
  • Versatile Installation Options
    A point-to-point connection uses a single CAT6/5e cable and requires no drivers, software, or IP configuration, significantly reducing setup time. The HDMI extender can be mounted on a wall, ceiling, or the underside of a table using the included brackets, offering versatile professional installation options. The HDMI extender offers a longer range than HDMI cables, and Ethernet cables are easier to run in walls, behind furniture, or through cable trays. Its compact form factor makes it ideal for boardrooms, digital signage, trade shows, and classrooms.
StarTech.com HDMI Extender Over CAT5e/6 Kit, 4K 60Hz, Up to 200ft (60m) - video/audio extender - HDMI
Video/audio extender
External
North America, Europe, United Kingdom, Australia, New Zealand
HDMI
Transmission Medium
CAT 5/5e/6
Max Transfer Distance
60 km
Power Over Ethernet (PoE)
PoC
AC 100-240 V
External
Wired
HDMI
Max Resolution
3840 x 2160 @ 60 Hz
60 km
Status Indicators
HDR support, 7.1 channel audio support, Dolby Digital support, DTS support, metal housing
HDCP 2.2
1 x HDMI output (local unit) - Type A female , 1 x HDMI input (local unit) - Type A female , 1 x network (local unit) - RJ-45 female , 1 x USB (power input) - Type C female , 1 x HDMI output (remote unit) - Type A female , 1 x network (remote unit) - RJ-45 female
Wall/ceiling mounting bracket kit
RoHS, WEEE, RCM, Plug and Play
PoC
External power adapter
AC 100-240 V
10 Watt
Limited warranty - 2 years , - 2 years
-20 °C
60 °C
0 - 90% RH (non-condensing)
J4KV StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
J4KV StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £18.52
