You can install the HDMI capture card into any low-profile or full-profile PCIe slot, including fixed workstations such as 2U or 4U rack-mounted servers or media centers.
Astonishing picture quality at 60 frames per second
With frame rates up to 60fps (frames per second) and H.264 encoding, this PCIe HDMI capture card is perfect for capturing ultra high-definition video for editing, compiling, and archiving. HDR10 is available through HDMI 2.0a support. -
H.264 encoding for wide device compatibility
The software included with the 4K60 capture card encodes captured video in H.264 - the most widely adopted video compression standard in the world. This video recording card ensures your captures are compatible with most device platforms such as PC, Mac, iOS and Android. -
Pass-through port
The UHD capture card features an HDMI output port so you can watch the video source on a separate HDMI display while recording on your computer.
- StarTech.com PCIe HDMI Capture Card, 4K 60Hz PCI Express HDMI 2.0 Capture Card w/ HDR10, UHD Video Capture Device for Desktop, PCIe x4 Video Recorder/Adapter/Live Streaming, H.264 Support - Video Capture/Recording (PEXHDCAP4K) - video capture adapter - PCIe x4
- Video capture adapter
- Interface Type
- PCIe x4
- 6.9 cm x 13 cm x 1 cm
- Included Input Adapter Accessories
- Low-profile bracket
- Video Input
- HDMI
- Video Modes
- 2160/60p
- Analogue Video Format
- NTSC, PAL, PAL-M, PAL 60
- Digital Video Format
- MPEG-4, H.264
- Digital Video Capture Speed
- 60 frames per second
- Digital Video Capture Resolution
- 4096 x 2160
- OS Required
- Windows 8 / 10
- 2-year warranty
- Interface Type
- PCIe x4
- 6.9 cm
- 13 cm
- 1 cm
Video
- Interface Type
- HDMI
- Video Modes
- 2160/60p
- MPEG-4, H.264
- 4096 x 2160
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A
- Compatible Slots
- 1 x PCI Express x4
- Included Accessories
- Device Features
- DirectShow compatible
- FCC, RoHS, WEEE, DCI (Digital Cinema Initiatives)
- OS Required
- Windows 8 / 10
- Shipping Width
- 14.4 cm
- Shipping Depth
- 20.7 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 230 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.37 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
