StarTech.com HDMI Capture Card - PCIe - UHD 4K 60Hz - For Windows
Quicklinx: GCQFWS00 Mfr#: PEXHDCAP4K
Type: Video capture adapter
Compatibility: PC
Interface: PCI Express x4
Hurry, only 2 left in stock!
£303.52 ex VAT
£364.22 inc VAT
You can install the HDMI capture card into any low-profile or full-profile PCIe slot, including fixed workstations such as 2U or 4U rack-mounted servers or media centers.
  • Astonishing picture quality at 60 frames per second
    With frame rates up to 60fps (frames per second) and H.264 encoding, this PCIe HDMI capture card is perfect for capturing ultra high-definition video for editing, compiling, and archiving. HDR10 is available through HDMI 2.0a support.
  • H.264 encoding for wide device compatibility
    The software included with the 4K60 capture card encodes captured video in H.264 - the most widely adopted video compression standard in the world. This video recording card ensures your captures are compatible with most device platforms such as PC, Mac, iOS and Android.
  • Pass-through port
    The UHD capture card features an HDMI output port so you can watch the video source on a separate HDMI display while recording on your computer.
StarTech.com PCIe HDMI Capture Card, 4K 60Hz PCI Express HDMI 2.0 Capture Card w/ HDR10, UHD Video Capture Device for Desktop, PCIe x4 Video Recorder/Adapter/Live Streaming, H.264 Support - Video Capture/Recording (PEXHDCAP4K) - video capture adapter - PCIe x4
Interface Type
PCIe x4
6.9 cm x 13 cm x 1 cm
Included Input Adapter Accessories
Low-profile bracket
Video Input
HDMI
Video Modes
2160/60p
Analogue Video Format
NTSC, PAL, PAL-M, PAL 60
Digital Video Format
MPEG-4, H.264
Digital Video Capture Speed
Digital Video Capture Resolution
4096 x 2160
Windows 8 / 10
Interface Type
PCIe x4
6.9 cm
13 cm
1 cm
Video
Interface Type
HDMI
Video Modes
2160/60p
MPEG-4, H.264
4096 x 2160
1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A
Compatible Slots
1 x PCI Express x4
Low-profile bracket
Device Features
DirectShow compatible
FCC, RoHS, WEEE, DCI (Digital Cinema Initiatives)
Windows 8 / 10
Shipping Width
14.4 cm
Shipping Depth
20.7 cm
Shipping Height
3.8 cm
Shipping Weight
230 g
20 - 80% (non-condensing)
GCQF StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.03
GCQF StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.55
GCQF StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.54
Compatibility: PC
