StarTech.com HDMI Cable - Gripping 90cm
Quicklinx: J1MKWS00 Mfr#: HDMI2-CABLE-GRIP-3F
Length: 90cm
47 In Stock
£4.90 ex VAT
£5.88 inc VAT
The 3ft High Speed HDMI Cable w/Gripping Connectors by StarTech.com offers connectivity for HDMI devices. Equipped with 19-pin HDMI Type-A connectors on both ends, this cable supports resolutions up to 4K at 60Hz and 1080p at 240Hz. The aluminum mylar foil shielding minimizes electromagnetic interference, while the strain relief feature enhances durability, making it suitable for various setups including monitors, TVs, and displays. With a lifespan of 10,000 insertions and a bend lifespan of 2,000 cycles, this HDMI cable is designed for regular use and provides a stable connection for streaming, gaming, or professional applications.
  • Reliable connectivity
    The 3ft High Speed HDMI Cable features 19-pin HDMI Type-A connectors that provide a strong and secure connection to a variety of devices, ensuring smooth data transmission.
  • High performance
    Capable of delivering resolutions up to 4K at 60Hz, this cable also supports 1080p at 240Hz and 2K at 144Hz, making it suitable for high-definition video playback and gaming.
  • Enhanced durability
    Designed with strain relief and robust construction, this cable offers a lifespan of 10,000 insertions and 2,000 bends, ensuring reliable functionality over time.
  • EMI protection
    Crafted with aluminum mylar foil and braid shielding, this HDMI cable minimizes electromagnetic interference, ensuring clear signals for an uninterrupted viewing experience.
  • Secure grip
    The gripping connectors on this cable provide a secure fit when connecting to devices, reducing the risk of accidental disconnections during use.
StarTech.com 3ft High Speed HDMI Cable w/Gripping Connectors, 4K 60Hz - HDMI cable with Ethernet - 90 cm
Cable
High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Length
90 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
Cable Type
High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
90 cm
Plated Connector
Gold
Recommended Use
Display, monitor, TV
HDR 10 support, Audio Return Channel (ARC), 18 Gbps data rate, HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), gripping connectors, 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, EMI protection, outer diameter 6mm
Connector
19 pin HDMI Type A - male
HDCP 2.2, WEEE, RoHS
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
0.5 cm
Limited warranty - lifetime
Length: 90cm
