StarTech.com HDMI Cable - Gripping 3m
Quicklinx: J1MHWS00 Mfr#: HDMI2-CABLE-GRIP-10F
Length: 3m
Hurry, only 3 left in stock!
£6.55 ex VAT
£7.86 inc VAT
The 10ft High Speed HDMI Cable w/Gripping Connectors by StarTech.com delivers reliable connectivity for your HD devices. With a design featuring aluminum mylar foil shielding and a braid, it ensures reduced EMI interference for optimal performance. This cable supports a range of resolutions including 4K at 60Hz, 1080p at 240Hz, and 2K at 144Hz, making it suitable for monitors, TVs, and displays. The gripping connectors provide secure connections, while the strain relief feature enhances durability, ensuring it can withstand frequent use. With HDMI Ethernet Channel support and HDR 10 compatibility, this cable enhances your viewing experience by providing vibrant visuals and immersive audio through its 32 audio channels.
  • Robust construction
    This HDMI cable features a shielded design, using aluminum mylar foil and a braid to reduce EMI interference, ensuring a clear signal and high-quality output for your audio and video devices.
  • High resolution support
    Capable of supporting resolutions up to 4K at 60Hz, along with 2K at 144Hz and 1080p at 240Hz, this cable is designed to handle demanding graphics, making it suitable for gaming and HD media consumption.
  • Gripping connectors
    The specially designed gripping connectors ensure a tight and secure connection, minimizing the risk of disconnections during use, perfect for video conferencing or gaming setups.
  • Durability features
    Engineered with a lifespan of 10000 insertions and 2000 bends, this HDMI cable is built to endure the rigors of everyday use, providing long-lasting reliability in any environment.
  • Enhanced audio visual experience
    Offering features such as HDR 10 support and 32 audio channels, this cable enhances your viewing experience with stunning visuals and immersive sound, ideal for home theaters and entertainment setups.
StarTech.com 10ft High Speed HDMI Cable w/Gripping Connectors, 4K 60Hz - HDMI cable with Ethernet - 3 m
Cable
High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Length
3 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
Cable Type
High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
3 m
Plated Connector
Gold
Recommended Use
Display, monitor, TV
HDR 10 support, Audio Return Channel (ARC), 18 Gbps data rate, HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), gripping connectors, 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, EMI protection, outer diameter 6mm
Connector
19 pin HDMI Type A - male
HDCP 2.2, WEEE, RoHS
Shipping Width
29 cm
Shipping Depth
14.5 cm
Shipping Height
0.8 cm
Limited warranty - lifetime
Length: 3m
