StarTech.com HDMI Cable - Gripping 35ft
Quicklinx: J4L0WS00 Mfr#: HDMI2-CABLE-GRIP-35F
Length: 10.6m
£62.55 ex VAT
£75.06 inc VAT
Connect to a 4K UHD TV or monitor, using this High Speed HDMI Cable. The connector markings enable quick visual identification, distinguishing this cable from other similar-looking or unmarked HDMI cables. Eliminate guesswork and always choose the appropriate cable to support full HDMI 2.0 capabilities. The HDMI UHD Cord features gold-plated gripping connectors to prevent accidental disconnections. The gripping connectors attach securely to HDMI device ports to minimize signal disruptions, and is ideal for critical A/V setups such as security systems and HDMI switches This High Speed HDMI Cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Gold-plated connectors are rated to operate beyond 10,000 insertions. The HDMI Monitor Cable supports full HDMI 2.0 features, including resolutions up to 4K 60Hz using a compatible HDMI source and display, high refresh rates including 1440p 144Hz and 1080p 240Hz, 21:9 Aspect Ratio, High Dynamic Range (HDR10) for higher contrast ratio, High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display, Audio Return Channel (ARC), Up to 32 Uncompressed Digital Audio Channels, HDMI Ethernet Channel (HEC) for network connectivity over HDMI, and backward compatible with previous HDMI versions. This HDMI 2.0 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
  • Gripping Connectors
    The HDMI UHD Cord features gold-plated gripping connectors to prevent accidental disconnections. The connectors attach securely to HDMI device ports, making this cable ideal for critical A/V setups such as security systems and HDMI switches.
  • Durable Design
    The HDMI Monitor Cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Gold-plated connectors are rated to operate beyond 10,000 insertions.
  • Supported HDMI 2.0 Features:
    This High Speed HDMI Cable supports full HDMI 2.0 features: • Resolutions up to 4K 60Hz using a compatible HDMI source and display • Supports high refresh rates including 1440p 144Hz and 1080p 240Hz • 21:9 Aspect Ratio support for cinematic viewing experiences • High Dynamic Range (HDR10) for higher contrast ratio and vibrant picture quality • High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display • Audio Return Channel (ARC) for sending audio from the TV back to an AV receiver or soundbar • Up to 32 Uncompressed Digital Audio Channels • HDMI Ethernet Channel (HEC) for network connectivity over HDMI • Backward compatible with previous HDMI versions This HDMI 2.0 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
StarTech.com 35ft (10.6m) Active HDMI Cable w/Gripping Connectors - HDMI cable with Ethernet - 10.6 m
Cable
High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
24/26
Length
10.6 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Cable Type
High Speed - HDMI cable with Ethernet active, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Shielded
24/26
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
10.6 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), 4k(2160p)@60Hz / 1440p@144Hz / 1080p@240Hz, 32 audio channels, 10000 insertions lifespan, 2000 bend lifespan, outer diameter 9 mm, gripping connectors, marked connectors, strain relief, halogen free, EMI protection, 21:9 cinema aspect ratio
Connector
19 pin HDMI Type A - male
HDCP 2.2, RoHS, WEEE
Shipping Width
33 cm
Shipping Depth
25.2 cm
Shipping Height
1.5 cm
Shipping Weight
500 g
Limited warranty - lifetime
Length: 10.6m
