StarTech.com HDMI Cable - Gripping 1.8m
Quicklinx: J1MLWS00 Mfr#: HDMI2-CABLE-GRIP-6F
Length: 1.8m
£5.80 ex VAT
£6.96 inc VAT
The 6ft High Speed HDMI Cable with Gripping Connectors from StarTech.com is designed for optimal connectivity and performance. Utilizing shielded technology, this HDMI cable provides protection against EMI while ensuring a robust signal. The aluminum mylar foil with braid shielding enhances durability, allowing for up to 10,000 insertions and a bend lifespan of 2,000 cycles, making it ideal for use in various applications including monitors, TVs, and displays.
This cable features gripping connectors for a secure fit and includes support for advanced technology features such as HDR 10, HDMI Ethernet Channel, and Audio Return Channel. With a data rate of 18 Gbps and support for high resolutions, including 4K at 60 Hz, 2K at 144 Hz, and 1080p at 240 Hz, it provides a high-quality audiovisual experience suitable for all your entertainment needs.
  • Robust Construction
    This HDMI cable features aluminum mylar foil with braid shielding, providing excellent durability and minimizing electromagnetic interference, ensuring reliability during usage.
  • Impressive Performance
    With a data rate of 18 Gbps, this cable supports multiple video resolutions including 4K at 60 Hz and 2K at 144 Hz, enabling vibrant visuals and seamless viewing experiences.
  • Secure Connections
    Equipped with gripping connectors, this cable ensures a secure connection to devices, reducing the risk of accidental disconnections during use.
  • Long-Lasting Reliability
    Designed for heavy use, this cable boasts a lifespan of up to 10,000 insertions and 2,000 bends, making it a dependable choice for various applications.
  • Environmentally Friendly
    This HDMI cable is compliant with RoHS and WEEE standards, ensuring it is halogen-free and safe for the environment.
StarTech.com 6ft High Speed HDMI Cable w/Gripping Connectors, 4K 60Hz - HDMI cable with Ethernet - 1.8 m
Cable
High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
Cable Type
High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
1.8 m
Plated Connector
Gold
Recommended Use
Display, monitor, TV
HDR 10 support, Audio Return Channel (ARC), 18 Gbps data rate, HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), gripping connectors, 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, EMI protection, outer diameter 6mm
Connector
19 pin HDMI Type A - male
HDCP 2.2, WEEE, RoHS
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
0.6 cm
Limited warranty - lifetime
Length: 1.8m
