The 6ft High Speed HDMI Cable with Gripping Connectors from StarTech.com is designed for optimal connectivity and performance. Utilizing shielded technology, this HDMI cable provides protection against EMI while ensuring a robust signal. The aluminum mylar foil with braid shielding enhances durability, allowing for up to 10,000 insertions and a bend lifespan of 2,000 cycles, making it ideal for use in various applications including monitors, TVs, and displays.
This cable features gripping connectors for a secure fit and includes support for advanced technology features such as HDR 10, HDMI Ethernet Channel, and Audio Return Channel. With a data rate of 18 Gbps and support for high resolutions, including 4K at 60 Hz, 2K at 144 Hz, and 1080p at 240 Hz, it provides a high-quality audiovisual experience suitable for all your entertainment needs.
Robust Construction
This HDMI cable features aluminum mylar foil with braid shielding, providing excellent durability and minimizing electromagnetic interference, ensuring reliability during usage. -
Impressive Performance
With a data rate of 18 Gbps, this cable supports multiple video resolutions including 4K at 60 Hz and 2K at 144 Hz, enabling vibrant visuals and seamless viewing experiences. -
Secure Connections
Equipped with gripping connectors, this cable ensures a secure connection to devices, reducing the risk of accidental disconnections during use. -
Long-Lasting Reliability
Designed for heavy use, this cable boasts a lifespan of up to 10,000 insertions and 2,000 bends, making it a dependable choice for various applications. -
Environmentally Friendly
This HDMI cable is compliant with RoHS and WEEE standards, ensuring it is halogen-free and safe for the environment.
- StarTech.com 6ft High Speed HDMI Cable w/Gripping Connectors, 4K 60Hz - HDMI cable with Ethernet - 1.8 m
- Cable
- High Speed - HDMI cable with Ethernet
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 1.8 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
- Limited lifetime warranty
- Cable Type
- High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
- Technology
- Shielded
- 30
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1.8 m
- Plated Connector
- Gold
- Recommended Use
- Display, monitor, TV
- HDR 10 support, Audio Return Channel (ARC), 18 Gbps data rate, HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), gripping connectors, 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, EMI protection, outer diameter 6mm
- Black
- Connector
- 19 pin HDMI Type A - male
- HDCP 2.2, WEEE, RoHS
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 0.6 cm
- Limited warranty - lifetime
