StarTech.com HDMI Audio Extractor - 1080p
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: C1K4WS00 Mfr#: HD2A
16 In Stock
£12.79 ex VAT
£15.34 inc VAT
Extract and convert the audio from your HDMI signal to 3.5mm audio in 2.1 stereo sound. This HDMI audio extractor lets you separate stereo audio from your HDMI video signal and connect it to a 3.5mm audio device, such as your stereo sound system or desktop speakers. You can also extract the audio from the HDMI signal and integrate it into an optical TOSLINK application, using the included digital SPDIF adapter.
Your latest consumer A/V equipment probably only offers an HDMI output. This can make it difficult to integrate devices, such as your new Blu-ray player or computer system, with your existing audio equipment or desktop speakers.
The HDMI audio extractor is USB powered using the included power cable, for easy integration with your computer systems. The adapter also features a small footprint that discreetly blends into your hardware setup, for a uniform look.
With a 3.5mm audio output and a TOSLINK adapter included, the HDMI audio extractor lets you output audio to virtually any non-HDMI equipment, whether it's digital or analog. This makes the audio extractor great for any application where you need to connect your HDMI source to speakers that don't have an HDMI input - such as desktop speakers, or a classroom or boardroom sound system.
The audio extractor is HDCP enabled and HDMI 1.3b compliant, to ensure compatibility with your HDMI device. Plus, the HDMI output supports resolutions up to 1920x1080 (1080p) at 60Hz, to fit any HD application.
The HDMI audio extractor can also be used with an inexpensive MU1MFRCA dual-RCA composite adapter (sold separately) to integrate the audio from your HDMI source into 2-channel RCA audio applications.
StarTech.com HDMI Audio Extractor - HDMI to 3.5mm Audio Converter - 2.1 Stereo Audio - 1080p (HD2A) - HDMI audio signal extractor
Package Content
USB power cable, HDMI audio signal extractor, TOSLINK adapter
Package Content
HDMI input - 19 pin HDMI Type A , HDMI output - 19 pin HDMI Type A , USB - mini-USB Type B , Audio line-out - mini-phone stereo 3.5 mm
C1K4 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.80
C1K4 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.32
C1K4 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
C1K4 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.44
C1K4 StarTech.com 4K HDMI Audio Extractor In Stock £53.75
