StarTech.com HDMI 2-in-1 T-Adapter - HDMI to HDMI Mini or HDMI Micro Combo Adapter – F/M
Quicklinx: 9KZPWS00 Mfr#: HDACDFMM
Connect your HDMI Micro or HDMI Mini-equipped Smartphone or portable device to your HDMI-capable TV or Display. The HDACDFMM HDMI 2-in-1 T-adapter enables you to use a standard HDMI male-to-male cable to connect your HDMI Micro or HDMI Mini mobile devices, including your Smartphone, Tablet, Digital Camera, etc. to an HDMI-enabled TV or display.
With a Standard HDMI (type A) female connector, an HDMI Mini (type C) male connector, and an HDMI Micro (type D) male connector, you can easily make the necessary conversions and connect to a display, an HDTV or HDMI-capable projector virtually everywhere you go.
The 2-in-1 Multifunction HDMI to Mini or Micro HDMI adapter is a perfect solution for connecting your various mobile devices while avoiding the hassle of having to carry multiple adapters. Plus, the adapter features a compact and lightweight design that fits nicely into any carrying case.
The HDMI T-adapter features high quality, gold-tipped connectors that ensure peak connectivity.
StarTech.com HDMI 2-in-1 T-Adapter HDMI to HDMI Mini or Micro Combo Adapter - HDMI adapter - 3.16 cm
Cable
HDMI adapter
Length
3.16 cm
Connectors
19 pin mini HDMI Type C - male , 19 pin micro HDMI Type D - male
Connectors (Second End)
HDMI - female
P/N: HDMM30CM
Cable Type
HDMI adapter
Length
3.16 cm
Plated Connector
Gold
Connectors
19 pin HDMI Type A - female
RoHS
Limited warranty - lifetime
P/N: HDMM30CM
9KZP StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M In Stock £12.43
