StarTech.com HDD Caddy for the DRW115SATBK
Quicklinx: 76RMWS00 Mfr#: DRW115CADSBK
Turn additional 3.5in SATA hard drives into extra hot-swap drives for the DRW115SATBK. This hard drive caddy/drive tray can be used with StarTech.com's Aluminum 5.25in Rugged SATA Hard Drive Drawer, allowing you to hot swap an additional SATA hard drive.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com Spare Hard Drive Tray for the DRW115SATBK Mobile Rack - hard drive caddy
Hard drive caddy
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA 1.5Gb/s
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
2 fans, ball bearing cooling fan, data indicator, power indicator, shock protection, fan status indicator
Product Material
Aluminium
13 cm x 21.7 cm x 4.3 cm
0.6 kg
Hard drive caddy
3.5"
Product Material
Aluminium
Supported Interface
SATA 1.5Gb/s
Storage Controller
No CPU
Bays
1 x internal - 3.5"
1 x SATA 1.5Gb/s - SATA
1 storage - Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x external
13 cm
21.7 cm
4.3 cm
0.6 kg
