StarTech.com Half Size to Full Size Mini PCI Express Adapter
Quicklinx: 7NZ0WS00 Mfr#: HMPEXADP
Type: None
Compatibility: PC
£5.04 ex VAT
£6.04 inc VAT
The HMPEXADP Half-size to Full-size Mini PCI Express (PCIe) Adapter allows for almost any standard half-length PCIe Mini Card to be mounted into a system that only accepts standard full-length cards.
Designed for use in systems such as Mini-ITX and embedded computing, this Mini PCIe adapter is a complete pass-through that lets the Mini PCIe card function at full speed, all without any drivers or software to install.
StarTech.com Half Size to Full Size Mini PCI Express Adapter - riser card
Riser card
3 cm x 5 cm x 1 cm
10 g
Riser card
3 cm
5 cm
1 cm
10 g
Expansion Slots
1 (total) / 1 (free) x Mini PCI Express - half-length
Compatible Slots
1 x Mini PCI Express - full-height
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
5 °C
50 °C
Type: None
Compatibility: PC
Price Range Ex VAT: 0 - 50
