StarTech.com Grounding Bar for Server Racks
Quicklinx: BL70WS00 Mfr#: GNDBAR1U
Product Type: Rack grounding bar
£34.34 ex VAT
£41.20 inc VAT
Protect up to ten devices in your server rack from static electricity damage, with this easy-to-access grounding strip. This 1U or 10U grounding bar offers a simple way to ground your valuable rack-mounted equipment. To help protect your investment, you can attach the bar to your server rack or cabinet to create a ground contact for your servers, KVM consoles, video switches and other network devices. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The grounding bar bridges your individual rack-mounted devices, allowing for static electricity to take a direct path to ground. Without a grounding path, your rack-mounted equipment can easily be damaged by electrical surges caused by static. The grounding bar protects your equipment from these surges, saving you the cost of replacing damaged equipment.
You can mount the grounding strip in any brand of standard server rack, using the included M5 screws and cage nuts.
StarTech.com Grounding Bar for Server Racks - 1U or 10U Copper Ground Strip rack grounding bar - 10U
Rack grounding bar
Package Content
12 M5 x 20mm screws, 2 M5 cage nuts
Height (Rack Units)
10U
48.2 cm x 2 cm x 0.5 cm
420 g
Rack grounding bar
Package Content
Height (Rack Units)
10U
48.2 cm
2 cm
0.5 cm
420 g
Limited warranty - 2 years , Technical support - lifetime
Price Range Ex VAT: 0 - 50
