Ensure reliable and cost-efficient Gigabit Ethernet connections with this RJ45 Mini-GBIC module. This StarTech.com Gigabit Copper SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into Cisco switches and routers that support the GLC-T SFP transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
This Gigabit RJ45 SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-T SFP transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi and single-port Gigabit Ethernet networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
You can count on GLCTST for reliable performance.
Efficient data transfer
This SFP module provides a data transfer rate of 1.25 Gbps, allowing for fast and reliable network communication. -
Wide temperature range
With an operating temperature range of 0°C to 70°C, this module can perform effectively in various environmental conditions. -
Seamless connectivity
Designed for Ethernet 1000Base-T, the module ensures compatibility with standard cabling for straightforward installation. -
Industry-compliant
This product adheres to UL, FCC, RoHS, WEEE, and MSA standards for dependable performance and environmental safety. -
Flexible installation
Features like auto-negotiation and auto-uplink make it easy to integrate into existing networks without extensive reconfiguration.
- Startech Cisco GLC-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, Cisco Firepower, ASR920, IE2000 Mini GBIC Transceiver - Lifetime Warranty (GLCTST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1.25 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-T
- 1.2 cm x 6.8 cm x 1.4 cm
- 25 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- 1GbE
- 1.25 Gbps
- 100 m
- Auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 female
- UL, FCC, RoHS, WEEE, MSA
- Cisco GLC-T
- 1.2 cm
- 6.8 cm
- 1.4 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £37.00 |
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £31.89 |
StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC | In Stock | £37.61 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com Fiber Media Converter - Open | In Stock | £43.33 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £328.89 |
