StarTech.com Gigabit RJ45 Copper SFP
Quicklinx: C198WS00 Mfr#: GLCTST
Type: Modules
£38.33 ex VAT
£45.99 inc VAT
Ensure reliable and cost-efficient Gigabit Ethernet connections with this RJ45 Mini-GBIC module. This StarTech.com Gigabit Copper SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into Cisco switches and routers that support the GLC-T SFP transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
This Gigabit RJ45 SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-T SFP transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi and single-port Gigabit Ethernet networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
You can count on GLCTST for reliable performance.
  • Efficient data transfer
    This SFP module provides a data transfer rate of 1.25 Gbps, allowing for fast and reliable network communication.
  • Wide temperature range
    With an operating temperature range of 0°C to 70°C, this module can perform effectively in various environmental conditions.
  • Seamless connectivity
    Designed for Ethernet 1000Base-T, the module ensures compatibility with standard cabling for straightforward installation.
  • Industry-compliant
    This product adheres to UL, FCC, RoHS, WEEE, and MSA standards for dependable performance and environmental safety.
  • Flexible installation
    Features like auto-negotiation and auto-uplink make it easy to integrate into existing networks without extensive reconfiguration.
StarTech.com Cisco GLC-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, Cisco Firepower, ASR920, IE2000 Mini GBIC Transceiver - Lifetime Warranty (GLCTST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1.25 Gbps
1GbE
Max Transfer Distance
100 m
Cisco GLC-T
1.2 cm x 6.8 cm x 1.4 cm
25 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1.25 Gbps
100 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female
UL, FCC, RoHS, WEEE, MSA
Cisco GLC-T
1.2 cm
6.8 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
C198 StarTech.com Gb MM SFP Fiber Transceiver In Stock £34.50
C198 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.13
C198 StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC In Stock £37.28
C198 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
C198 StarTech.com Fiber Media Converter - Open In Stock £42.26
C198 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Modules
