StarTech.com Gigabit PoE+ Extender - 100m
Quicklinx: BFPRWS00 Mfr#: POEEXT1GAT
Type: Repeater
£95.44 ex VAT
£114.52 inc VAT
Scale your Power over Ethernet connection by 100m, or daisy chain up to four extenders for longer distance. This Gigabit PoE+ extender spans your Power over Ethernet (PoE) device over longer distances, letting you double the 100m limitations of a traditional PoE infrastructure.
Now you can connect your Gigabit PoE device up to a maximum of 200m away, so it's easy to install a remote IP camera or access point. Plus the extender can be daisy-chained for more scalability.
Need more distance? This convenient PoE+ repeater maximizes range and flexibility by extending your PoE connection by an extra 100m (330ft), while providing 24-watt power output to compatible devices.
Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered device (PD) and you're all set. The extender is compliant with the 802.3at/af standard, so it will work with existing PSE, such as a StarTech.com POEINJ1G PoE+ injector (POEINJ1G) or IES81000POE PoE+ switch (IES81000POE).
Still need more distance? If an extra 100m isn't enough, this full-featured PoE extender offers daisy chain capability.
You can easily connect four extenders together, letting you install your PoE+ PD up to 500m (1640ft) away. It's perfect for business, education, and retail environments (output wattage is dependent on the number of daisy-chained extenders used).
Get up and running quickly. This Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter.
You can enjoy reliable performance with little worry of downtime or failure, the extender features a rugged metal housing with built-in ESD and surge protection.
  • Unrestricted PoE+ range and convenience
    Need more distance? This convenient PoE+ repeater maximizes range and flexibility by extending your PoE connection by an extra 100m (330ft), while providing 24-watt power output to compatible devices. Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered device (PD) and you're all set.
  • Daisy chain for longer distance and flexibility
    Still need more distance? If an extra 100m isn't enough, this full-featured PoE extender offers daisy chain capability. You can easily connect four extenders together, letting you install your PoE+ PD up to 500m (1640ft) away. It's perfect for business, education, and retail environments (output wattage is dependent on the number of daisy-chained extenders used).
  • Convenient installation options and durable construction
    Get up and running quickly. This Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter. You can enjoy reliable performance with little worry of downtime or failure, the extender features a rugged metal housing with built-in ESD and surge protection.
StarTech.com 1 Port Gigabit PoE+ Extender 802.3at & 802.3af - 100m (330ft) - Power over Ethernet Extender - PoE Repeater Network Extender (POEEXT1GAT) - repeater - 10Mb LAN, 100Mb LAN, 1GbE
Repeater
External
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Max Transfer Distance
100 m
Power Over Ethernet (PoE)
PoE+
9.4 cm x 7 cm x 2.6 cm
197 g
P/N: ST12MHDLANU
Repeater
External
Wired
Cabling Type
100 m
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, 2KV ESD Protector
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 , 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45
MTBF
50,000 hours
EN 61000-4-2, EN 61000-4-5, FCC, RoHS
PoE+
3.2 Watt
9.4 cm
7 cm
2.6 cm
197 g
50 °C
5 - 95% (non-condensing)
P/N: ST12MHDLANU
BFPR StarTech.com 100 ft Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £32.38
BFPR StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £32.38
BFPR StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £206.76
BFPR StarTech.com 4 Port Gigabit PoE+ Injector In Stock £122.70
BFPR StarTech.com Gigabit PoE+ Extender - 100m In Stock £95.44
Type: Repeater
