StarTech.com Gigabit Fiber SFP - 10 Pack
Quicklinx: C197WS00 Mfr#: GLCLHSM10PST
Type: Modules
£229.47 ex VAT
£275.36 inc VAT
Maximize cost-savings and performance with this bulk pack of single-mode/ multi-mode Mini-GBIC modules. Perfect for large-scale deployments or installations on multiple devices, this bulk pack of Gigabit fiber SFPs provides maximum cost savings. Built to exacting specifications and fully tested to ensure optimum performance, these high-quality transceiver modules can be installed into Cisco switches and routers that support the GLC-LH-SM transceiver module, as well as other major brands of networking equipment.
The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your 1000Base-LX/LH networking equipment, and they're backed by a lifetime warranty.
The single-mode/multimode SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit single-mode/multimode SFPs are engineered to the highest quality standards and are 100% Cisco compatible, equivalent to the Cisco GLC-LH-SM SFP transceiver. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these fiber transceivers are fully hot-pluggable which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support both single-mode (with a maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.) and maximum data rates up to 1.25Gbps.
You can count on GLCLHSM10PST for reliable performance,.
StarTech.com Cisco GLC-LH-SM Compatible SFP Module, 1000BASE-LX/LH, 1GbE SMF Optic Transceiver, LC Connector, 10km, 1310nm Cisco Firepower, ASR920, IE2000 Mini GBIC Transceiver 1GE SFP - Lifetime Warranty (GLCLHSM10PST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Packaged Quantity
10 (specifications are for single item)
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Cisco GLC-LH-SM
1.37 cm x 5.66 cm x 1.25 cm
25 g
Packaged Quantity
Plug-in module
Silver
Wired
Cabling Type
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode
IEEE 802.3z
1 x Ethernet 1000Base-LX/1000Base-LH - LC female x 2
FCC, RoHS, MSA
Cisco GLC-LH-SM
1.37 cm
5.66 cm
1.25 cm
25 g
Limited warranty - lifetime
70 °C
5 - 95%
C197 StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
C197 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
C197 StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.49
C197 StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.84
C197 StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.65
C197 StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.31
C197 StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.13
C197 StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.13
C197 StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.44
C197 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £146.10
C197 StarTech.com Fiber Media Converter - Open In Stock £43.33
C197 StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £228.89
C197 StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.48
C197 StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £37.59
C197 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £328.89
Type: Modules
