StarTech.com Gigabit Fiber SFP - 10 Pack
Quicklinx: C17TWS00 Mfr#: GLCLHSMD10ST
Type: Transceiver
£223.31 ex VAT
£267.97 inc VAT
Maximize cost-savings and network performance with this bulk pack of single-mode/multi-mode Mini-GBIC modules. Perfect for large-scale deployments or installations on multiple devices, this bulk pack of Gigabit fiber SFPs provides maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, these high-quality transceiver modules can be installed into Cisco switches and routers that support the GLC-LH-SMD transceiver module, as well as other major brands of networking equipment.
The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your 1000Base-LX/LH networking equipment, and they're backed by a lifetime warranty.
The SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit single-mode SFPs are engineered to the highest quality standards and are 100% Cisco compatible, equivalent to the Cisco GLC-LH-SMD SFP transceiver. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these Gigabit fiber transceivers are fully hot-pluggable which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a multitude of Gigabit fiber networking devices.
Ideal for use in switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support auto-negotiation, a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 1.25Gbps.
You can count on GLCLHSMD10ST for reliable performance.
  • Reliable connectivity
    This SFP transceiver module supports wired connectivity technology, ensuring effective data transmission over Ethernet 1000Base-LX and 1000Base-LH cabling types.
  • Versatile temperature range
    Operating effectively between 0°C and 70°C, this module is suitable for various environments, making it a dependable option for diverse networking applications.
  • Enhanced monitoring capabilities
    The integration of Digital Diagnostics Monitoring Interface (DDMI) allows for real-time performance tracking, ensuring optimal operation and quick problem resolution.
StarTech.com Cisco GLC-LH-SMD Compatible SFP Module, 1000BASE-LX/LH, 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 1GE Gigabit Ethernet, LC Connector, 10km 1310nm, Firepower, ASR920 (GLCLHSMD10ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Packaged Quantity
10 (specifications are for single item)
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Cisco GLC-LH-SMD
Packaged Quantity
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring Interface (DDMI), auto-uplink (auto MDI/MDI-X)
IEEE 802.3z
1 x Ethernet 1000Base-LX/1000Base-LH - LC female x 2
MSA, FCC, UL, RoHS
Cisco GLC-LH-SMD
Limited warranty - lifetime
70 °C
C17T StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.56
C17T StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £23.49
C17T StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £19.15
C17T StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.62
C17T StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.25
C17T StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £23.55
C17T StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.09
C17T StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £18.98
C17T StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
C17T StarTech.com Fiber Media Converter - Open In Stock £42.26
C17T StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.31
C17T StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £218.03
C17T StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £37.25
C17T StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.87
C17T StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Transceiver
