Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km). The EOC1110K Gigabit Ethernet over Coaxial Unmanaged LAN Extender Kit (2.4km) includes both end points, and allows you to span a 10/100/1000Mbps Ethernet network over extremely long distances (up to 2.4 km/1.5 mi) while still maintaining high-speed network connectivity.
The coax Ethernet extender allows you to run the connection over existing coaxial cable, with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from the same or separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless connectivity may be impossible.
The gigabit Ethernet over coax kit helps to eliminate expense by allowing CCD or CATV video and Ethernet network data to share the same coaxial cable without interference.
- StarTech.com Gigabit Ethernet over Network Extender Kit - 2.4km IP to Coax Converter - RJ45 LAN Ethernet to RG6 Coax Internet Adapter Kit (EOC1110K) - short-haul modem - GigE
- Short-haul modem - RJ-45 / F connector
- Form Factor
- External
- Cabling Type
- 10Base-T, 100Base-TX, 1000Base-T, Coax
- Data Link Protocol
- GigE
- Max Transfer Distance
- 2.4 km
- Power
- AC 120/230 V
- 13.8 cm x 28 cm x 7.7 cm
- 300 g
- 2-year warranty
- Designed For
- P/N: EOC1110R, SVA12M2NEUA, SVA12M5NA
- Short-haul modem
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- GigE
- 2.4 km
- Status Indicators
- Power, link/activity
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 2 x network - F connector
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 4 Watt
- 13.8 cm
- 28 cm
- 7.7 cm
- 300 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £44.06 |
