Convert and extend a Gigabit Ethernet connection over fiber using the Gigabit SFP of your choice. The ET91000SFP2 Open SFP Fiber Media Converter converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
The fiber to Ethernet converter has a durable all-steel chassis and offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
For added versatility, this Gigabit media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For applications where multiple chassis-mounted media converters are required, this Gigabit media converter can be purchased as a Card Module only (ET91000SFP2C).
- StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot - fibre media converter - 100Mb LAN, GigE
- Fibre media converter - RJ-45 / SFP (mini-GBIC)
- Form Factor
- External
- Cabling Type
- 1000Base-SX, 100Base-LX, 1000Base-T
- Data Transfer Rate
- 1.25 Gbps
- Data Link Protocol
- 100Mb LAN, GigE
- 9.5 cm x 2 cm x 16 cm
- 400 g
- 2-year warranty
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 100Mb LAN, GigE
- 1.25 Gbps
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Jumbo Frames support
- IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000 - SFP
- MTBF
- 65,000 hour(s)
- FCC, RoHS, MSA
- 9.5 cm
- 2 cm
- 16 cm
- 400 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £71.70 |
StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km | In Stock | £239.09 |
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £127.49 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £115.23 |
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £305.47 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £42.04 |
StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter | In Stock | £483.18 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £39.96 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC) | In Stock | £38.71 |
StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot | In Stock | £99.41 |
StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot | In Stock | £92.23 |
