StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot
Quicklinx: 93WMWS00 Mfr#: ET91000SFP2C
Convert and extend a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice. The ET91000SFP2C Open SFP Fiber Media Converter card module converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
Designed for applications where multiple chassis-powered media converters are required, this Gigabit media converter ships as a card module that can easily be installed into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For standalone operation this Gigabit media converter can also be purchased as a standard Open SFP Media Converter (ET91000SFP2).
The fiber to Ethernet converter offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
StarTech.com Gigabit Ethernet Fiber Media Converter Card Module w/ Open SFP Slot - Fiber to Ethernet Converter - Ethernet Media Converter (ET91000SFP2C) - fibre media converter - GigE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1.25 Gbps
GigE
7.5 cm x 14 cm x 2 cm
100 g
P/N: ET10GSFP, GLCSXMMRGDST, J4858C10PKST, J4858CST
Plug-in module
Wired
Cabling Type
1000Base-TX
GigE
Data Transfer Rate
1.25 Gbps
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Jumbo Frames support
IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-TX - RJ-45 , 1 x Ethernet 1000Base-X - SFP
MTBF
65,000 hour(s)
FCC, RoHS, MSA
7.5 cm
14 cm
2 cm
100 g
60 °C
10 - 90% (non-condensing)
93WM StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £40.45
93WM StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £150.73
93WM StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £148.89
93WM StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps In Stock £316.48
93WM StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £24.09
93WM StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £24.09
93WM StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £228.89
93WM StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.48
93WM StarTech.com GbE Fiber Media Converter 10km In Stock £183.62
