StarTech.com Gb MM SFP Fiber Transceiver
Quicklinx: 6BDHWS00 Mfr#: SFPSXMM
Type: Transceiver
24 In Stock
£42.40 ex VAT
£50.88 inc VAT
Add, replace or upgrade SFP modules on gigabit fiber equipment. The SFPSXMM Gigabit 850nm Multi Mode SFP Fiber Optical Transceiver - LC 550m is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to increase performance and connectivity of your fiber-connected network devices.
Using a short wavelength (850nm) VCSEL laser diode, enabling a maximum cable distance of 550m (0.3 miles) over multi mode fiber, this Small Form Factor Pluggable (SFP) Gigabit Multi Mode module can be installed into any fiber networking devices with an MSA compliant SFP port, providing a simple solution to upgrade existing network devices to connect to remote locations using LC terminated multimode fiber.
Delivering convenience and scalability, the optical transceiver allows you to install the multimode LC module without interrupting network traffic or requiring a device reboot.
StarTech.com MSA Uncoded Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, 1Gbps Mini GBIC Module - Lifetime Warranty (SFPSXMM) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.3 cm x 5.5 cm x 0.9 cm
18 g
P/N: MCM1110SFP
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Full duplex capability
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
CSA, UL, TUV, FCC, RoHS
1.3 cm
5.5 cm
0.9 cm
18 g
70 °C
5 - 95%
P/N: MCM1110SFP
6BDH StarTech.com Gb MM SFP Fiber Transceiver In Stock £42.40
6BDH StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.22
6BDH StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £27.07
6BDH StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £17.35
6BDH StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £21.31
6BDH StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC In Stock £37.80
6BDH StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £42.81
6BDH StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £43.94
6BDH StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £26.11
6BDH StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £26.34
6BDH StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £160.38
6BDH StarTech.com Fiber Media Converter - Open In Stock £48.56
6BDH StarTech.com Gb RJ45 Copper SFP - 10 Pack In Stock £266.91
6BDH StarTech.com Gigabit RJ45 Copper SFP In Stock £40.14
6BDH StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £368.50
6BDH StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T In Stock £48.71
Type: Transceiver
