Add reliable, cost-efficient Gigabit Ethernet connections over single-mode/multi-mode fiber with this Mini-GBIC module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the GLC-LH-SMD transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade the ports on your 1000Base-LX/LH networking equipment, and it's backed by a lifetime warranty.
This single-mode/multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM/MM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-LH-SMD SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports Digital Diagnostics Monitoring and both single-mode (with maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.). It provides maximum data rates of up to 1.25Gbps.
You can count on GLCLHSMDST for reliable performance.
Versatile connectivity options
This SFP module features LC connectors with two ports, ensuring compatibility and ease of use in various networking settings. -
Reliable temperature range
Operates efficiently from 0°C to 70°C, making it suitable for diverse operating environments. -
Compliance with standards
Meets various compliance standards such as UL, FCC, RoHS, and MSA, providing peace of mind regarding safety and quality. -
Enhanced data link performance
Utilizes Gigabit Ethernet protocol compliant with IEEE 802.3z, contributing to stable network performance. -
Advanced features for functionality
Includes features such as full duplex mode and auto MDI/MDI-X for optimized connectivity and performance.
- StarTech.com Cisco GLC-LH-SMD Compatible SFP Module, 1000BASE-LX/LH, 1GbE Single Mode (SMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM, Firepower - Lifetime Warranty (GLCLHSMDST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX, 1000Base-LH
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-LH-SMD
- 0.9 cm x 6.5 cm x 1.4 cm
- 25 g
- Limited lifetime warranty
- Designed For
- P/N: IES101G2SFPW, IES101GP2SFW
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Auto-uplink (auto MDI/MDI-X), full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LX/1000Base-LH - LC female x 2
- UL, FCC, RoHS, MSA
- Cisco GLC-LH-SMD
- 0.9 cm
- 6.5 cm
- 1.4 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- Designed For
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £13.98 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £23.49 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £15.11 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £19.15 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.62 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £23.89 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £24.50 |
StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £20.78 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £23.55 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £17.09 |
StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £18.98 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £139.16 |
StarTech.com Fiber Media Converter - Open | In Stock | £42.26 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £223.31 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £218.03 |
StarTech.com Gb Fiber SFP - Cisco Compatible | In Stock | £37.25 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £223.87 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £320.87 |
