Strong and sleek, this full-motion TV wall mount lets you free up space by wall-mounting your 32" to 75" TV, and adjust it to the right viewing position with ease.
Once it's installed, the flat-screen TV wall mount is simple to adjust without using tools. You can extend the arms with ease to position your TV anywhere from 4.1" to 21.6" (105 to 550 mm) away from the wall. The TV mount swivels +/-60 degrees and tilts +/-15 degrees for optimum viewing.
This premium television wall mount beautifully combines form and function. Designed to provide an impressive appearance in every position, the premium black and silver design makes it ideal in a company lobby or hallway, information kiosk, or living space. With the arms extended, the protective covers provide a tidy, professional look. The cable-management channel inside the arms keeps cables neatly tucked away.
Engineered with steel and aluminum, the robust TV mount securely supports a TV with a maximum weight capacity of 187.4 lb. (85 kg).
Smooth Full-Motion Adjustability
Once it's installed, the flat-screen TV wall mount is simple to adjust without using tools. You can extend the arms with ease to position your TV anywhere from 4.1" to 21.6" (105 to 550 mm) away from the wall. The TV mount swivels +/-60 degrees and tilts +/-15 degrees for optimum viewing. -
Sleek Design
- StarTech.com Full Motion TV Wall Mount, Heavy Duty Articulating TV Wall Mount Bracket for 32" to 75" (165lb/75kg) VESA Display, Universal Adjustable Tilt/Swivel Flat Screen Arm, Silver - Cable Management (FPWARPS) bracket - for TV - black, silver
- Product Type
- Bracket - wall-mountable
- 87 cm x 55 cm x 52.4 cm
- Tilt
- -15° to 15°
- Swivel
- -60° to 60°
- Adjustments
- Tilt, swivel
- Recommended Use
- TV
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
- Max Load Weight
- 85 kg
- Material
- Plastic, aluminium, steel
- Black, silver
- Package Content
- Hex key (6mm), TV mount, 2 x vertical brackets, 4 x flat washers, 2 x vertical bracket screws, 8 x concrete anchors, 8 x wall screws, 4 x M4 x 12 mm screws, 4 x M4 x 18 mm screws, 4 x M5 x 12 mm screws, 4 x M6 x 12 mm screws, 4 x M6 x 18 mm screws, 4 x M8x 12 mm screws, 4 x M8 x 18 mm screws
- 2-year warranty
- 87 cm
- 55 cm
- 52.4 cm
- Material
- Black, silver
- Package Content
AV Furniture
- Bracket
- Recommended Use
- TV
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 32"-75"
- Tilt
- -15° to 15°
- Swivel
- -60° to 60°
- Adjustments
- Tilt, swivel
- Max Load Weight
- 85 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 2 kg
- Limited warranty - 2 years
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.85 |
StarTech.com Flat-Screen TV Wall Mount | In Stock | £50.35 |
StarTech.com Full Motion TV Mount - Steel | In Stock | £60.06 |
StarTech.com Low Profile TV Mount - Tilting | In Stock | £48.81 |
StarTech.com Low Profile TV Mount, Fixed | In Stock | £35.60 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.22 |
StarTech.com VESA TV Wall Mount Full Motion | In Stock | £85.31 |
