StarTech.com Full Motion TV Wall Mount
Quicklinx: F2KKWS00 Mfr#: FPWARPS
Type: Bracket
Hurry, only 3 left in stock!
£247.82 ex VAT
£297.38 inc VAT
Strong and sleek, this full-motion TV wall mount lets you free up space by wall-mounting your 32" to 75" TV, and adjust it to the right viewing position with ease.
Once it's installed, the flat-screen TV wall mount is simple to adjust without using tools. You can extend the arms with ease to position your TV anywhere from 4.1" to 21.6" (105 to 550 mm) away from the wall. The TV mount swivels +/-60 degrees and tilts +/-15 degrees for optimum viewing.
This premium television wall mount beautifully combines form and function. Designed to provide an impressive appearance in every position, the premium black and silver design makes it ideal in a company lobby or hallway, information kiosk, or living space. With the arms extended, the protective covers provide a tidy, professional look. The cable-management channel inside the arms keeps cables neatly tucked away.
Engineered with steel and aluminum, the robust TV mount securely supports a TV with a maximum weight capacity of 187.4 lb. (85 kg).
  • Smooth Full-Motion Adjustability
  • Sleek Design
StarTech.com Full Motion TV Wall Mount, Heavy Duty Articulating TV Wall Mount Bracket for 32" to 75" (165lb/75kg) VESA Display, Universal Adjustable Tilt/Swivel Flat Screen Arm, Silver - Cable Management (FPWARPS) bracket - for TV - black, silver
Bracket - wall-mountable
87 cm x 55 cm x 52.4 cm
Tilt
-15° to 15°
Swivel
-60° to 60°
Adjustments
Tilt, swivel
Recommended Use
TV
Recommended Display Size
32"-75"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
Max Load Weight
85 kg
Material
Plastic, aluminium, steel
Black, silver
Package Content
Hex key (6mm), TV mount, 2 x vertical brackets, 4 x flat washers, 2 x vertical bracket screws, 8 x concrete anchors, 8 x wall screws, 4 x M4 x 12 mm screws, 4 x M4 x 18 mm screws, 4 x M5 x 12 mm screws, 4 x M6 x 12 mm screws, 4 x M6 x 18 mm screws, 4 x M8x 12 mm screws, 4 x M8 x 18 mm screws
87 cm
55 cm
52.4 cm
Material
Black, silver
Package Content
AV Furniture
Bracket
Recommended Use
TV
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
32"-75"
Tilt
-15° to 15°
Swivel
-60° to 60°
Adjustments
Tilt, swivel
Max Load Weight
85 kg
Dimensions & Weight Details
2 kg
F2KK StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.75
F2KK StarTech.com Flat-Screen TV Wall Mount In Stock £51.61
F2KK StarTech.com TV Wall Mount - Steel In Stock £142.52
F2KK StarTech.com Full Motion TV Mount - Steel In Stock £61.55
F2KK StarTech.com Low Profile TV Mount - Tilting In Stock £50.04
F2KK StarTech.com Low Profile TV Mount, Fixed In Stock £35.93
F2KK StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £80.17
F2KK StarTech.com VESA TV Wall Mount Full Motion In Stock £87.44
Type: Bracket
