Save space by mounting a flat-panel television to your wall, with easy tilt for ideal viewing. Maximize space while creating an impressive display with this heavy-duty wall mount for large flat-screen TVs or monitors. The flat-panel wall mount securely supports a VESA Mount compliant TV from 32" to 70", with easy-to-use tilt adjustment for comfortable viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, while saving valuable space. The wall mount is ideal for boardrooms, lobbies or other venues providing an impressive and secure way to display a large flat-panel TV or create digital signage. The robust wall mount supports a large 32" to 70" flat-screen TV weighing up to 165 lb. (75 kg).
The TV wall mount lets you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. The tilt-adjusting knobs make it easy to adjust your TV to the ideal viewing angle.
The hook-and-mount design of the TV wall mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you then hang your TV securely onto the wall mount. Cable management helps to keep cables out of view.
Ideal for the Boardroom, or Digital Signage
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, while saving valuable space. The wall mount is ideal for boardrooms, lobbies or other venues providing an impressive and secure way to display a large flat-panel TV or create digital signage. The robust wall mount supports a large 32" to 75" flat-screen TV weighing up to 165 lb. (75 kg). -
Tilt Your Display to the Ideal Viewing Angle
- StarTech.com Flat Screen TV Wall Mount - Tilting - Supports 32" to 75" TVs - Steel - VESA TV Mount - Monitor Wall Mount (FLATPNLWALL) mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall plate, 2 mounting brackets
- 81 cm x 8.3 cm x 50 cm
- Tilt
- -15° to 15°
- Adjustments
- Tilt
- 3.8 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
- Max Load Weight
- 75 kg
- Material
- Steel
- Black
- Package Content
- Allen key, 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 6 x flat washers, 6 x concrete anchors, 6 x 6.3x55 mm screws, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws
- 2-year warranty
- Designed For
- P/N: HDMIPLATE
- 81 cm
- 8.3 cm
- 50 cm
- 3.8 kg
- Material
- Steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 32"-75"
- Tilt
- -15° to 15°
- Adjustments
- Tilt
- Max Load Weight
- 75 kg
- Limited warranty - 2 years
- Designed For
- P/N: HDMIPLATE
StarTech.com Flat-Screen TV Wall Mount
