StarTech.com Finger Duct Cable Panel - 3ft.
Quicklinx: CGVZWS00 Mfr#: CMVER20UF
£47.31 ex VAT
£56.77 inc VAT
Organize your cables in any rack or cabinet that's 20U or larger, using this vertical cable management panel. This 3-foot vertical cable manager gives you a simple and space-efficient way to organize the cables in your server rack. You can attach the cable manager vertically into your rack, to neatly guide cables between equipment that's mounted at different heights.
The 0U cable manager offers versatile installation options and is compatible with most racks that are 20U or larger. The panel features a 0U design that doesn't take up any mounting space, and with simple tool-less installation, it's easy to attach or reposition as necessary.
The vertical cable manager uses a finger-duct method of cable management, which includes a cover panel that neatly conceals the cables that are running through it. The cable manager runs vertically along the side of your rack, to neatly guide cables between equipment that's mounted at different heights. This provides a tidy and well-organized way to run cables from devices mounted toward the bottom of your rack to other devices mounted near the top, without leaving a mess of cables hanging in between.
Having neatly organized and routed cables not only improves the appearance and accessibility of your rack, it also makes it easier for you to install, access and maintain rack components.
For maximum compatibility with virtually any server rack, you can install the cable-management panel using mounting holes that are commonly found on most rack equipment. The tool-less mounting method attaches the cable management panel to the keyhole-shaped mounting holes that are built into your rack.
The horizontal mounting rail method attaches the cable management panel to the horizontal mounting rails that run along the side of your rack.
For racks that don't support these installation methods, you can also mount the cable management panel through other means, such as using the non-standardized holes found on your rack walls and enclosures, or the rack units on equipment mounting rails.
Routing your cables through a panel reduces the tension that's often put on cables. This prevents cable damage or connection loss, and reduces strain on equipment ports, preventing damage to your expensive rack-mounted devices.
Properly routing cables also improves airflow, which passively cools devices stored in your rack, helping to keep your equipment running at optimal temperatures to reduce the probability of damage caused by your rack overheating.
StarTech.com 3ft (1m) Vertical Cable Management Duct with Cover - 0U Open Slot Finger Duct Wire Raceway for 19 Inch Server Rack - Slotted Cord Channel (CMVER20UF) - cable organizer - 20U
Cable organizer
Package Content
4 x screws, 2 nuts, 4 x nuts
Length
91.4 cm
Product Material
Steel, plastic
Height (Rack Units)
20U
P/N: RK2537BKM, RK4242BK24, RK4242BK30
Cable organizer
Package Content
Product Material
Steel, plastic
Height (Rack Units)
20U
Length
91.4 cm
Enclosure Colour
Mounting Kit
Included
Vertical orientation, front mountable, rear mountable
CGVZ StarTech.com D-Ring Hook Cable Panel - 6ft. In Stock £67.06
CGVZ StarTech.com D-Ring Hook Cable Panel - 3ft. In Stock £39.24
CGVZ StarTech.com Finger Duct Cable Panel - 6ft. In Stock £90.20
CGVZ StarTech.com Finger Duct Cable Panel - 3ft. In Stock £47.31
CGVZ StarTech.com 1U Rack-Mount Cable Lacing Bar In Stock £11.81
