StarTech.com Fiber to RJ45 Media Converter
Quicklinx: J1L2WS00 Mfr#: D01ML55U-FIBER-MEDIA
£111.76 ex VAT
£134.11 inc VAT
  • Reliable connectivity
    The media converter provides a stable connection between fiber and Ethernet networks, with a maximum transfer distance of 10 km.
  • Robust design
    Constructed with a metal housing, this converter withstands various environmental conditions while maintaining performance.
  • Versatile compatibility
    This device is compliant with multiple standards such as IEEE 802.3z and IEEE 802.3ab, ensuring it works with a wide array of devices.
  • Efficient power usage
    Using only 2.5 W during operation, this powered device ensures low energy consumption while providing functionality.
  • User-friendly installation
    The Plug-and-Play feature allows for easy setup, enabling users to quickly connect without needing extensive technical knowledge.
StarTech.com Gigabit Fiber to RJ45 Ethernet Media Converter, Micro Mini - fibre media converter - 1GbE - TAA Compliant
Fibre media converter - RJ-45 / LC single-mode / LC multi-mode
External
Cabling Type
1000Base-T, 1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
8.24 cm x 2 cm x 1.75 cm
49 g
TAA Compliant
External
Silver
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Status Indicators
Power, link/activity, fibre
USB powered, metal housing, auto-negotiation, auto-uplink (auto MDI/MDI-X), Link Fault Pass-Through (LFPT) support, latching, EMI protection, unmanaged, Marvell 88E1512 chipset
IEEE 802.3ab, IEEE 802.3z, USB 1.1
1 x Ethernet 1000Base-T - RJ-45 male , 1 x Ethernet 1000Base-LX - LC single-mode / LC multi-mode female x 2 , 1 x USB - Type A male
USB cable - 30 cm
Plug and Play, IP20, WEEE, Laser Class 1
TAA Compliant
2.5 Watt
8.24 cm
2 cm
1.75 cm
49 g
Shipping Width
13.6 cm
Shipping Depth
8 cm
Shipping Height
3.2 cm
Shipping Weight
80 g
50 °C
5 - 85% RH
J1L2 StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
J1L2 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
J1L2 StarTech.com 15m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £29.25
