StarTech.com Fiber to RJ45 Media Converter
Quicklinx: J1JXWS00 Mfr#: D01ML55P-FIBER-MEDIA
£112.53 ex VAT
£135.03 inc VAT
The StarTech.com Gigabit Fiber to RJ45 Ethernet Media Converter is a versatile solution designed to meet the demands of modern network infrastructures. It facilitates the connection between fiber optic and copper networks, featuring RJ-45 and LC single-mode/multi-mode connectors for broad compatibility. With a data transfer rate of 1 Gbps and a maximum transfer distance of 10 km, it ensures high-speed, reliable connections over long distances.
Built for durability, the converter boasts a robust metal housing and is equipped with features such as 2 KV surge protection, EMI protection, and compliance with Laser Class 1 and IP20 standards, ensuring it can operate in a variety of environmental conditions. Additionally, its support for Power over Ethernet (PoE) simplifies installation by reducing the need for additional power cables. Whether for expanding network reach or integrating different network types, this media converter is an efficient, reliable choice.
  • Robust connectivity
    This Gigabit Fiber to RJ45 Ethernet Media Converter bridges the gap between fiber and copper networks, offering seamless integration with RJ-45 and LC single-mode/multi-mode connectors. It's designed to support a wide range of networking environments, ensuring reliable connectivity across different media types.
  • Enhanced durability
    Constructed with a metal housing and equipped with over-temperature, over-current, and over-voltage protection, this media converter is built to withstand harsh conditions. Its 2 KV surge protection and EMI protection further ensure uninterrupted service and longevity.
  • Efficient operation
    Features like Link Fault Pass-Through (LFPT) support, auto-negotiation, and auto-uplink enhance the device's operational efficiency. The inclusion of a Marvell 88E1512 chipset supports high-performance data transmission, making it a suitable solution for demanding network tasks.
  • Power over Ethernet
    The ability to be powered via PoE simplifies deployment by eliminating the need for a separate power source. This feature, combined with its compact form factor, makes the converter an excellent choice for locations where space and power outlets are limited.
  • Comprehensive compliance
    Adhering to multiple standards including IEEE 802.3ab, IEEE 802.3af, and IEEE 802.3z, and being TAA-compliant, this media converter meets rigorous regulatory requirements. Its compliance with Laser Class 1 and IP20 standards also ensures safe and reliable operation.
StarTech.com Gigabit Fiber to RJ45 Ethernet Media Converter, Micro Mini - fibre media converter - 1GbE - TAA Compliant
Fibre media converter - RJ-45 / LC single-mode / LC multi-mode
External
Cabling Type
1000Base-T, 1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Power Over Ethernet (PoE)
PoE
DC 30 - 57 V
8.2 cm x 2 cm x 1.7 cm
42 g
TAA Compliant
P/N: 50FIBLCLC10, 50FIBLCLC15, N6PATCH6BL, N6PATCH6BL10PK
External
Silver
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Status Indicators
Power, link/activity, fibre
Metal housing, EMI protection, unmanaged, over-voltage protection, over-current protection, over temperature protection, 2KV Surge protection, Link Fault Pass-Through (LFPT) support, latching, Marvell 88E1512 chipset, auto-negotiation, auto-uplink (auto MDI/MDI-X), PoE powered
IEEE 802.3af, IEEE 802.3ab, IEEE 802.3z, USB 1.1
1 x Ethernet 1000Base-T - RJ-45 male , 1 x Ethernet 1000Base-LX - LC single-mode / LC multi-mode female x 2 , 1 x USB - Type A
Plug and Play, IP20, WEEE, Laser Class 1
TAA Compliant
PoE
DC 30 - 57 V
8.2 cm
2 cm
1.7 cm
42 g
Shipping Width
13.6 cm
Shipping Depth
8 cm
Shipping Height
3.2 cm
Shipping Weight
75 g
55 °C
5 - 85% RH
J1JX StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
J1JX StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
J1JX StarTech.com 15m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £29.25
