StarTech.com Fiber Optical Cable 5m MPO / MTP
Quicklinx: DXFHWS00 Mfr#: MPO12PL5M
Terminate twelve fiber connections using a single 40 Gigabit network cable - designed for high-density fiber networks. This MPO/MTP fiber optic cable houses 12 fibers and lets you interface between different networking devices of varying speeds. For example, you can set up a one-to-one connection between two 40Gbps switches or servers. Alternatively, you can connect a 40Gbps switch and break out the 40Gbps into six duplex 10Gbps LC connections on a patch panel or network cassette, which then fans out to individual 10Gbps devices.
The MTP connector provides twelve times the density of an SC connector and saves circuit card and rack space. Plus, the push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand, without having to use additional tools.
The MTP to MTP cable is housed in a plenum-rated jacket and is ideal for installations where CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
StarTech.com MTP Fiber Optic Cable - 15 ft / 5m - OM3 - 40Gb - Push / Pull Tab - Plenum - MPO / MTP Connector - Fiber Patch Cable (MPO12PL5M) - network cable - 5 m - aqua
Network cable - OM3
Fibre optic
Type of Fibre Optics
Multimode
Plenum
Length
5 m
Core / Cladding Diameter
50 / 125 micron
Connector
MTP/MPO multi-mode - female - push/pull
Connector (Second End)
Aqua
Network Cable Type
Network cable - OM3
Fibre optic
Multimode
50 / 125 micron
Plenum
Length
5 m
40.9 g
Aqua
Connector
RoHS
