StarTech.com Fiber Optic Cable Cleaner
Quicklinx: J4LDWS00 Mfr#: FOCLEANER
26 In Stock
£16.65 ex VAT
£19.98 inc VAT
Ensure optimal performance with this practical fiber optic cleaner, designed for LC, SC, ST, and FC fiber connectors. It provides quick, effective cleaning for reliable signal quality in critical network environments. Maintain Clean Fiber Connections This Fiber Optic Cleaner effectively removes dust and particles to prevent contamination that can compromise connection reliability and signal quality. Because optical fiber is highly sensitive to contamination, keeping fiber ends clean is essential for maintaining consistent performance, especially in high-bandwidth connections where even minor particles can disrupt signal integrity. Quick and Simple Operation Cleaning fiber connector ends is simple with the intuitive push-button mechanism. Simply press to expose the cleaning belt, then swipe the fiber connector to remove particulate matter and ensure a clean contact surface in just a few quick motions. For Professional Fiber Installations This Optical Fiber Cleaning Tool is suited for fiber optic network maintenance, server racks, and data centers. Its compact design is ideal for technicians working with high-density fiber setups, including patch panels and transceivers. Compatible with both APC and UPC-polished fiber ends, it supports a wide range of fiber connection types.
  • Maintain Clean Fiber Connections
  • Quick and Simple Operation
  • For Professional Fiber Installations
StarTech.com Fiber Optic Cleaner, Fiber Cable Cleaner for LC/SC/ST/FC - fibre-optic cleaning tool
Fibre-optic cleaning tool
13 cm x 8 cm x 3.5 cm
147 g
Green
RoHS, WEEE
13 cm
8 cm
3.5 cm
147 g
Enclosure Colour
Green
Up to 500 cleanings
RoHS, WEEE
Shipping Width
23 cm
Shipping Depth
9 cm
Shipping Height
4 cm
Shipping Weight
180 g
-10 °C
50 °C
Type: Fibre-optic cleaning tool
