Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multimode LC fiber. The ET91000LC2 1000 Mbps Gigabit Multimode Fiber Media Converter (LC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, this GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet-to-fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable SFP slot.
Efficient data transfer
Experience Gigabit Ethernet performance with a data transfer rate of 1 Gbps, ensuring swift and efficient data transmission for your network. -
Flexible connectivity
Equipped with both RJ-45 and LC multi-mode connectors, this media converter adapts easily to various networking configurations, enhancing versatility. -
Durable design
Designed to withstand environmental challenges, this device operates within a temperature range of 0°C to 60°C, making it suitable for a variety of settings. -
User-friendly setup
Plug-and-play compatibility allows for a straightforward installation process, enabling users to quickly integrate the device into their existing network. -
Long-range capability
Extend network connections efficiently with a maximum transfer distance of 550 m, facilitating robust networking over larger areas.
- StarTech.com Multimode (MM) LC Fiber Media Converter for 1Gbe Network - 550m Range - Gigabit Ethernet - 850nm - with SFP Transceiver (ET91000LC2) - fibre media converter - 1GbE
- Fibre media converter - RJ-45 / LC multi-mode
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Cabling Type
- 1000Base-LX, 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- Power
- AC 120/230 V
- 9.5 cm x 16 cm x 2 cm
- 0.62 kg
- 2-year warranty
- Designed For
- P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2
- MTBF
- 65,000 hours
- Plug and Play, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 9.5 cm
- 16 cm
- 2 cm
- 0.62 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90%
- Designed For
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £147.04 |
StarTech.com Fiber Media Converter - Open | In Stock | £42.26 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £66.05 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £179.13 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.72 |
