StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m
Quicklinx: 85DGWS00 Mfr#: ET91000LC2
Type: Media Converter
10 in stock
£129.09 ex VAT
£154.90 inc VAT
Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multimode LC fiber. The ET91000LC2 1000 Mbps Gigabit Multimode Fiber Media Converter (LC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, this GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet-to-fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable SFP slot.
StarTech.com Multimode (MM) LC Fiber Media Converter for 1Gbe Network - 550m Range - Gigabit Ethernet - 850nm - with SFP Transceiver (ET91000LC2) - fibre media converter - GigE
Fibre media converter - RJ-45 / LC multi-mode
External
North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.62 kg
P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2
MTBF
65,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.62 kg
60 °C
10 - 90%
85DG StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.55
85DG StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.85
85DG StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £129.09
85DG StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter In Stock £488.43
Price Range Ex VAT: 100 - 150
